Morning all,
inspired by Pete and his love of these things I dug out my Meng M4 last night and started chopping bits off it
There may just be enough time to get this in before the end of the GB
But first.....
the base kit for the build
I hadn't really appreciated just how small these things are until I shook the contents from the deceptively large box
it is tiny
sanded off the track guards from the bottom of the hull then attacked the engine deck
removed all the lumps and bumps and filled the holes with bits of plastic
next I chopped the rear sides and bent back the rear hull plate as per 1:1 - gives a bit more room in the engine bay
that was as far as I got but it's a start
next task will be to trim the plastic filler pieces and smear filler all over the place
But first.....
it is tiny
