Eduard\Revell British S.E.5a
peterairfix
Not done a biplane in a while so I have this one in my stash to butcher while I wait for so stuff through the post for my nex main project.
This kit is a direct reboxing of the Eduard kit and as ever it's a quality kit with lots of nice tiny pieces to lose there won't be much airbrushing as the part's are so small I will brushing most of the kit
Here's some of what I have done it's mostly paintwork.
And for size indication all those squares are one centimetre.20190620_105345.jpg20190620_105414.jpg20190620_105850.jpg20190620_105820.jpg20190620_105933.jpg20190620_105948.jpg20190620_110241.jpg
Very impressed with the effect on the propeller blades.
How did you do it?
Peter.
I'm in, oap seating with nurse please.
If the prop is a taste of what's going to follow it should be good .:thumb2:
How did you do it?
I first did a coat of tamiya wooden deck tan.
And then I used this20190623_092839.jpgfollwed from the set above I first dry coated in the first shade20190623_092848.jpgAnd then a light coat of this to get the grain effect and topped off with a coat of mig gloss varnish.20190623_092858.jpg
Hi Peter
The number of kits which get reboxed, updated, new decals etc can be very confusing. Eduard are usually nice kits. Some of those parts are indeed tiny. As others have said the wooden prop is very realistic.
Started on the the cockpit and as ever it's a bit fiddly but I did get together and a bit more wood staining still needs some work.20190623_113816.jpg20190623_133829.jpg20190623_165421.jpg
Cockpit finished and bracing wires added and now sat in the bottom wing.20190624_132138.jpg20190624_132118.jpg
Here's today's work started on the two fuselage sides made up the engine and have it seem up and engine installed.20190625_151902.jpg20190625_151913.jpg20190625_153031.jpg20190625_183241.jpg20190625_191252.jpg
Almost finished just rigging and decals to go but with the thickness of the rigging it might be another few weeks before it's done.20190627_151623.jpg20190627_152610.jpg20190627_184647.jpg20190627_185427.jpg20190627_185505.jpg
I had forgotten about this one until I found it lurking at the back of the shelf and the I found out why that because I couldn't face the rigging but I just picked it up and got on with it so it's my first real attempt it's complete but just needs tiding up.20200221_162525.jpg20200221_162537.jpg20200221_162601.jpg20200221_162628.jpg
Peter.
Is that my old mat ? :smiling2:
Great build I love how you get those cables so tight, prop looking most realistic as well .:thumb2:
