Pete's Stummel
stillp
Rugby
I was going to build a 1/48 plane next, but this fell off the pile and I couldn't be bothered to put it back:
A Hasegawa 1/72 Sd.Kfz.234/3 8-RAD Schwere Panzerspahwagen, 'Stummel' for short.
I like armoured cars - no canopy, and no tracks! Seems to have quite a few parts, certainly more than the Vampire.
Hope they all fit.
Yet Another vehicle I’d like to build! Interested to see how it goes together:smiling4:
Afternoon Pete,
Looks a nice kit with lots of detail so I'll sit in if I may…..
According to the thread title though, wouldn't a new razor blade take care of the problem???
I'll get me coat...……………………………..
Very good Allen. Now repeat 100 times "stuBBle"
:tongue-out3:
I'm rather impressed with this kit. There's NO flash that I can see, just some visible seam lines in some places, easily removed with a couple of scrapes with a scalpel. The engineering is good too, with many of the sprue attachments being out of sight when assembled. Plenty of fine detail on the suspension:
and in the interior, though those ejector marks might need some work:
The wheels and tyres are separate, so I've painted the tyres.
For some reason, the tyres on 2 of the wheels are different from the other 7 (including the spare), hence the '5' and '6' on the rolled paper used to hold them for painting.
So, the first 20 or so parts are together, so I'm taking a break while the cement dries.
Thanks for watching.
Settling in for this.
And I've already learned something. Rolled up paper for supporting tyres. So simple it's genius.
Andy, I pinched the idea from Dave Ward .
Arrived just in time Pete. Off to a great start. Looking forward to seeing how it turns out
These Hasegawa kits are quite good, certainly the later ones. The early ones are a bit iffy on the details, and the tanks usually have poor tracks, but I’ve never found one with flash or fit problems.
As the charmingly mistranslated instructions say "After making it dry enough, it advances to the following distance", so I let things dry for a while, then advanced to "An indoor assembly", i.e. the interior.
The angle of the steering wheel for the forward driving position looks odd, but it's correct, according to a walkaround at https://www.net-maquettes.com/pictures/sd-kfz-234-3/
The underside currently looks like this:
Nicely detailed. The instruction suggest adding the wheels at this stage, but I'll leave them until some painting has been done. I think I'll spray some sandgelb on the inside before adding the upper hull.
The steering wheels on many of these kinds of German vehicles were like that, yes. The SdKfz 250 and 251 halftracks had them the same way, for example. It saves space and lets the driver get in and out more easily in a hurry, at the expense of requiring more effort to turn the wheel.
The gun is complete, and I've fitted the inner halves of the wheels - I'll paint the outer halves separately.
Inside has had a coat of sandgelb, as well as a bit of drybrushing, but I the camera has swallowed the photo.
Not much more assembly to do now, but quite a bit of painting.
Looking good. That's one way to assure all wheels hit the ground even. There were two tread designs used on these vehicles, so to see both on a vehicle was not unusual. Stores on fenders and std. antennae mount were also subject to change. Is the co-ax there or yet to come? I couldn't make it out. PaulE
Yet to come Paul. As well as the two tread designs there seem to be two different wheels - the 2nd one back on each side looks to have a couple of cut-outs. These aren't shown on the box art or the painting guide.
Stubble, Stubble, Stubble, Bubble, Bubble, Trouble, Ah, Ah, Rubble, Gravel, Cobble Stones, Rolling Stones, Led Zeppelin...….Sorry, way too hard Pete!!!!!!!!!!!
Looking real good Peter and the details on this really stand out. Great job using the anti 'John Race' safety glue bottle to keep it level on the ground. You can't be careful enough these days and we wouldn't want the 234 going up in flames now, would we!!! Top Job Sir!!!
Allen
