Meng 1/48 F-35A Lightning II
Afternoon all. :)
Been having a bit of a mare with the paint. :(
There was a mark on one of the wings. I made a small mask with some of the spare vinyl and blew over it with the airbrush. After taking off the mask the painted section was a completely different shade. I have no idea why, it was the same bottle of paint thinned to the same ratio.
I tried to fix it by painting over the offending patch with neat paint and a brush, then gave it a light sanding. If anything this made it worse.
After scratching my head for a while I decided there was no choice but to respray both wings, so even more masking.
The end result is ok, both wings are a slightly different shade to the rest, but at least they match.
View attachment 350856View attachment 350857
Everything has now been glossed in preparation for decals.
Partly, but also to reduce the aircraft's radar signature.
The lighter colour is RAM (radar aborbing material) tape.
Superb masking work Bob, great result. Noone will ever notice the differing wing shades once it's decalled up and varnished
Cheers Joe. :)
You're right, still annoying after all that work though. The only thing I can think is maybe the air pressure was different so the metallic flakes dispersed differently??
That's a distinct possibility.
Along with other variables a change in air pressure will affect the droplet size. Larger, wetter droplets will give the flakes longer to settle down flat, reflecting more light. Smaller, dryer droplets can see the flakes drying at random angles, scattering light.
Hi Bob
Glad you sorted the wings. Annoying and rather strange but it is fine. As Joe says only you will know once it is decalled and finished. It will be a cracker.
Evening gents. :)
Update time. Over the weekend I glossed and got the decals down, then glossed again.
The last couple of evenings I've been weathering. As this is a relatively new service kite I didn't want to batter it, more of a general dirty feel. For this reason I went with a grime clay wash. Easy to apply and remove, pics up the rivet and line detail and leaves a little dirt in the corners.
The burner can was done with a combination of oils, enamels and pigment.
View attachment 351130View attachment 351131View attachment 351132View attachment 351133View attachment 351134View attachment 351135
Hi Bob
That is looking very nice indeed.
:thumb2: That's one hell of a masking job Bob, very nice
Cheers gents. :)
Decided to get the matt coat down last night at around 11pm when it was a bit cooler. Hopefully going to get the base board and pole sorted tonight and then it should be done.
