Coming along nicely Steve. Wouldn't it be better to glue some plastic card into those grooves then file/sand it down flush?Now the cons of having to do a kit designed for two different versions of the same model is that you have to add and take things away from the kit. In this instance I have to fill two large and deep groves on top of the mantle gubbins.
Not happy with this as the filler over time will split and crack. The only thing in my favour is that only a small part of this is noticable once put together.
Quite busy at the moment. We bought a bigger house but plenty of work to do on the inside. I did manage to score a huge hobby room so the future is looking brightHello Wouter. How are yer mate?? Chip in anytime if I am going wrong with the build
So … does setting yourself the goal of assembling those tracks count?I googled what you could do in 5 hours and here are the results
[snip]
#3 Set goals – Spend some time each day setting daily, monthly, and yearly goals. Life will become much more fun, and efficient, which in turn will free up more time. Wahoo!
There you go: Practice making model Panther tracks!#6 Practice – Add value to your life by mastering your new found passion. Everything from musical instruments to programming to road biking adds value to you as a person.
