Scotties Puma AAGB
Still plodding on with the etch with the addition of the spare wheel bracket, fixing one of the bins in place and the antenna base. The front bumper was added along with the etch braces. The top of the hull was also added.
Next up are the pioneer tools. First to be tackled is the Jack the kit offering id not very good at all. All the moulded in mounting bracket was removed which was a pain. Next a new foot was made from sheet and thin strip. A handle was made and finally a few rivets I need a way of making smaller rivets as they are a bit big but should be ok.
cheers
Scottie
The back end certainly is the DBs. Have you left the box open to see inside the engine or are you planning to put something in there??
Well the back end would be ! :smiling2::smiling2::smiling2:
Excuse us Paul .
Paul .
This is nothing short of perfection. Those hinges and the brass sheet work are something else, jaw dropping is right.
