Pete's Italeri 1/35 Kangaroo
Hi Steve & Si hope it all right if I
return and slaughter this one in your GB, I promise there won't be any minions.
Box Art
Parts
Instructions, decals and tracks.
I shall be building the Canadian version.
Pete.
Hi Pete,
Of course you are more than welcome. Not seen this kit before so interesting to see how it builds.
Good luck :thumb2:
Hi Pete,
Good luck :thumb2:
Hi Si and thank you yes it is different mainly used as a personnel carrier and i for anything take needed hauling, at least I know I used to be able to build a half decent Sherman but we will have to wait and see if I still can.
Pete.
Blimey Pete, there's no stopping you at the moment. Looks interesting.
Hi Pete
Skippy :smiling5: A new one on me as well. I'll hop into the front row next to Si.
The Kangaroo armoured personnel carrier.
A Kangaroo was a Canadian armoured personnel carrier (APC) during the Second World War, created by converting a tank chassis. Created as an expedient measure by the Canadian Army, Kangaroos were so successful that they were soon being used by British and Commonwealth forces.
Their ability to manoeuvre in the field with the tanks was a major advantage over earlier designs, and led to the dedicated APC designs that were introduced by almost all armies immediately after the war.
The earliest iterations of the Kangaroo were created from M3 and M5 Stuart light tanks to serve as artillery tractors in North Africa in circumstances where Universal Carriers were unavailable. They were effective in their role, but attempts by soldiers to use them as improvised APCs proved ill-advised due to the Stuart's very light armor.
In July 1944, Lieutenant-General Harry Crerar's First Canadian Army was concerned by manpower shortages due to combat losses. While the British and Canadian forces had received some American M3 Half-track APCs, the supply was heavily reduced by this point due to the Americans' own need for them, and Universal Carriers were individually insufficient despite the enormous numbers. However, self-propelled artillery guns and Tanks were currently oversupplied, with a significant number sitting idle not being used. Lieutenant-General Guy Simonds, commander of II Canadian Corps, devised Kangaroos as a field-expedient alternative to purpose-built APCs.
The original Kangaroos were converted from 72 M7 Priest self-propelled guns of three field artillery regiments of the 3rd Canadian Infantry Division. The Priests were "defrocked", removing their 105mm guns and ammunition stowage, and separating the driver's compartment from the rest of the vehicle. Priests with machine gun turrets retained them, and some that did not have organic mounts for machine guns had improvised ones fitted. When the 3rd Canadian Infantry Division was re-equipped with towed 25 pounder guns in late July, the rest of their self-propelled tracked vehicles were stripped of their 105mm guns and converted to Kangaroos. Later Kangaroos were based on Sherman, Churchill, and obsolete Canadian Ram tanks. The process was broadly similar, with the entire turret being removed, ammunition storage removed, bench seats being fitted in the turret ring area, and the driver's compartment separated. Hull machine guns were retained, and new machine guns were sometimes fitted to the turret ring. Kangaroos in general were supposed to carry 8 to 12 soldiers, though similar to the practice of troops riding on tanks, it was more common to simply cram as many as possible as could fit without being at risk of falling off.
The Priest Kangaroos were first used on 8 August 1944 south of Caen during Operation Totalize to supplement the half-tracks already available.[1] When re-converted Kangaroos were returned to U.S. custody, other vehicles were pressed into service, the vast majority (some 500) being Rams,[2] which were standing idle after being used as training vehicles when Canadian armoured formations re-equipped with Shermans. The Ram gun tanks were shipped to France and duly converted, deploying piecemeal as they arrived.
While 'debussing' - climbing out of the hull and jumping down, potentially under fire - was challenging, the obvious difficulty of getting into a vehicle that was designed to prevent enemy soldiers climbing onto it was quickly appreciated. Accordingly, climbing rungs were soon added as a field modification that also simplified loading the carrying compartment with ammunition, food and other supplies to troops under fire.
The Ram Kangaroo entered service piecemeal with the Canadians in September 1944, but in December these minor units were combined to form the 1st Canadian Armoured Carrier Regiment, joining the British 79th Armoured Division (whose specialized vehicles were called "Hobart's Funnies")
The first operation for the Ram Kangaroo was the assault on Le Havre, the last the 7th Armoured Division's march into Hamburg on 3 May 1945.
In Italy, Sherman III tanks and some Priests were converted for use by the British Eighth Army. Removing the turret of the Sherman and some internal fittings gave room for carrying up to 10 troops.
Pete.
Hi Pete
Hi Jim I thought better of you but I knew someone would, what's that Skip Jim has put popcorn is your pouch :rolling:.
Pete.
It’s Italeri’s old M7B1 Priest, minus the 105 mm howitzer and plus some plates :) I built it something like 30 years ago, and still have the (now wrecked) model in a cupboard somewhere.
In any case, it’s based on Italeri’s still quite good M4A1 (76) VVSS tank, and doesn’t really have anything important wrong with it. It may not be up to today’s standards, detail-wise, but should certainly be a very buildable kit, IMHO.
I'll settle in for this one Pete. I'll try not to make too much noise in the ball pool!
Evening, really like the history brings the vehicle to life and one i know bugger all about, and that goes for a lot of things outside of the world of the Stug!!
Cannot fault the effort sir!!!
Hi built up the six vvss units and will carry out the modification tomorrow.
Pete.
Cheers Bob I like to add a bit of background to the build with the history behind the vehicle , I think it's important to know what you are building.
Pete.
