update on the engine block! i airbrushed the three new parts added, what a difference it makes! it’s just a shame that the rest of the hand brushed work is so shoddy:tears-of-joy:
Hi, if you want to start the engine again, although what you've done looks good, you can always use VMS Clean slate, works a treat used it myself. I found that knowing you can rewind the painting it makes it easier to do, not so daunting.
Have fun, that's the main thing.
Coming along nicely Lachlan :smiling3:.
When it says surface primer it didn't mean the surface of your desk:tears-of-joy:.
Lachlan,
been there, done that! I've some abstract green patches under my workbench.............
Now, if I'm brush painting, I use a pallet, and if I'm on the airbrush, I use plastic shot glasses to mix up the correct consistency - At no point is an open paint pot ON my bench, it's only open in my hand. If I have an accident, it's only a small amount that needs cleaning up...............
Looking good Lachlan.
My floor around my spray area is covered in blobs of paint !
