Dambusters Lancaster BIII
If you can get it, use pre cut masks from eduard or such like....the cost is far outweighed by the time saved.....
Interesting. I won't bother on this one as it's just for practise, but my next will be a different matter. Thank you.
Anyway, put enough together to get the main paint job started.
I have to criticise this model a bit. As far as I'm concerned, the wings on a plane are quite an integral part. I imagine designers from Boeing might agree. Well these are flimsier than a politician's promise. They seriously need a brace column internally to allow pressure to be applied - squeeze the middle just a bit and the edges fold out. Cheap and nasty. Similar criticism of the fuselage. Contrast this to the Titanic model I did of theirs, which had bracing along the whole length. Anyway, I sorted it with some swearing.
Cover the whole canopy in masking tape and then cut out where the frame is. This is usually much simpler than trying to cut masking tape the size and shape of all those little glazing panels.
Also, once you’ve got the canopy masked, paint it first with the colour that the inside of the frame is to be (British cockpit green, I suppose) and only then do the exterior colour over the top of that. This way you’ll get the inside to look right too, with only one round of masking.
Going to give this a bash, nice tip on the inside/outside, hadn't thought of it.
Hi Andrew
Iconic aircraft that's for sure. Builds up into quite a big model even at 1/72.
From the start of construction I always plan the painting as I go along. I like to build as much as possible before painting. The reason for that is twofold. Firstly any sanding needed does not damage already done paintwork and secondly I find it almost impossible to join ready painted parts without glue marks.
Following with interest.
I’m the same way I hate to glue parts together after painting and can’t sand and fix what’s been painted then when you paint again you may get to many layers
Thought I'd show you just how challenged I am with a paintbrush.
Here's the camo in the instructions:
Here's what I managed:
Stuff it. This is going to be the Lancaster which they used for practice, testing with camo only on one wing.
Painting camo will be much easier if you draw it on the model with a pencil first. The diagrams in the instructions show the panel lines, which you can use to determine how the pattern runs on the model too: find where the edge of a patch crosses a panel line, and draw it in the same place on the same line on your model. This may take a little practice, but you’ll develop an eye for it and be able to draw the pattern well enough soon. Then you only need to paint more or less inside the lines, rather than having to get the paint in the right place without a guide.
Aye tried that - the lines were as bad! I'm not kidding, I have always had a complete brain block on this. I can do calligraphy, and am extremely dextrous, but cannot convert a visual image to an export.
For example, same sort of problem, I once witnessed a crime and had to give a description. I could not tell the coppers their hair typeor colour, height, eye colour, age etc. Fortunately, I was able to associate the geezer as a Rodney Trotter lookalike, and they worked back from there. It's an odd thing, because my memory is fine.
I experience synaesthesia, and have been told that while it isn't an illness, and is very useful in some ways, it does interfere with some things.
Anyway, it knackers my drawing and painting, looks like a 3 year old did it!
Do you paint over the lines afterwards, or erase them?
You probably need a little more practice :) I can’t draw either, except technical style, but the trick to drawing the camouflage onto a model is to use the panel lines as a guide. The handy thing here is that you can count them: the large patch you tried to paint on the wing, for example, begins halfway between the fuselage and the innermost fore–aft panel line and crosses the that first fore–aft line at about the halfway point too.
You’re a step ahead of most people here, in that you know you don’t have a good memory for this kind of thing. Most people think they do when in fact they’re very bad at it :)
I normally paint over them first, to make sure they’re out of sight, and then fill in the patches. It’s safest to check after you’re done and erase any you can still see, though.
Odd. I could have sworn I copied and pasted the line
Code:
[QUOTE="Bobby Conkers, post: 542909"]
from the top of the message for the second part of the quote. No idea how that came to refer to an entirely different post by you. I’ll just edit the post and correct it :)
Gremlins in the system Jakko :smiling5:
Apologies for the interlude Andrew.
Back on it. Engines on, final base paint job done. Now on to the spindly bits in every Revell kit which never quite fit without bending...
Had a bit of a disaster!
So finished my experimentation, put decals on, then decided to try out my Humbrol spray varnishes.
The Enamel Satin (135) has caused some cracking (all paint underneath is Revell enamel) like so:
Not quite dry yet but it isn't going to go away.
The Acrylic Matt varnish has done this, again, all on top of enamel!
Basically the acrylic varnish has clouded as you see everywhere it's gone.
Fortunately I'm not remotely bothered about this model, it was just to get my techniques going again, but I need to know for the future!
Help!
HI Bobby I see you had
WELL when I spray my big ships model costin a lot of money I try out all the paints an varnishes on a spare bit of plasticard to see if any will attack any of the others as if it does then just get a different make or such but never straight onto the model an I know you said It don't matter on this model but to me you was doin a nice job so next time exsperiment on an old bit of card so save yourself this greive
chris
Thank you Chris. Point taken, I will do this in future.
I think I've diagnosed this now. In order to provide adequate ventilation, I did it outside. I then left it to dry in the conservatory, at a temperature of 4 degrees. Too cold!
I've given it another coat and dried at room temperature. Another lesson learned.
Quick review of the model.
It reminded me why I don't do military. No criticism of those who do, of course, they're perfect for storytelling. To me though, I prefer colour and romance (which is why F1 cars and old boats!), I find military (necessarily) drab and brutish. I did this one because a friend and his kids bought this for me. I suppose I just like pretty!
On the model itself, as suspected the fiddly little bits were standard Revell substandard - it also suffers from being a compromise of the 'standard' Lancaster model (holes filled in for missing turrets, holes in the wings for missing guns etc.) as opposed to being bespoke.
I'm sure others would have enjoyed it more, but I wasn't inspired. A good learning experience for new techniques though.
