Scotties Humber Mk1
Finally got the hull all buttoned up the fit was quite good with a little bit of wiggling about. A little filler was needed here and there. I'm glad I didn't go overboard on the interior as the vast majority cannot be see as only the top hatches and drivers hatch will be open. I have also made a start on the hull details. Before i do any more I think I will replace the hull welds.
cheers
Scottie
Hi Scottie
That looks good. Must be quite a small model. Bring on the paint.
Thanks Jim,
Lots to do yet before the paint. It is quite small next time I take a pic I will put something next to it for size.
Always liked this vehicle, looks much cooler than the more common Daimler Scout Car, if you ask me. You’re certainly doing it justice.
Thanks Jakko, I have to agree it a nice looking vehicle
Dang Paul,
You messed around and closed the little fellow up. That must have hurt a bit my friend. All that hard work and you will hardly see any of it, but you have the satisfaction of knowing it is in there. Real nice so far with all the extra finery. Have you started painting up Michael Caine yet???
Allen
Dang Paul,
Allen
Hi Allen, Not to worried about the interior there should be enough to see if you look closely. Michael is still on the sprue :smiling3: Thanks for looking in fella.
Well it looks like you are off to a great start..love the eye candy on the interior..I know we’ll see the usual Scottie magic on this one..looking forward to watching this one
Hi Joe good to see you again
You may not see it Paul but we all know its there LOL. There's been a few times when I have put hulls together and had to remove some hard work to get it to fit. I'm so glad its worked out well for you. It's all down hill from here on in mate LOL
Added the welds from stretched sprue not that easy to see but didn't want them to big and chunky. I have also made a start on the bling.
Scottie
Hi Scottie
Those welds look good. Using stretched sprue is a technique I have always failed with :rolling: Don't know what I'm doing wrong! I have settled on thin worms of Milliput. Trouble with Milliput is that as you work along the weld doing the texturing the worm stretches ahead of you. So you have to re-position the worm or only work in short lengths.
Anyway sob story over - bring on the bling.
Hi Scottie
Hi Jim,
I can't get on with the milliput. I tried it again on this first before resorting to the sprue. I get half way through doing a length then it sticks to the scalpel and pulls the lot off. So I am probably doing it wrong.
I'm with you Paul. Can't get on with Milliput but fine with sprue. I use a heated blade to make the weld seam which prevents pulling off the sprue but creates it's own problems. Over to you JR LOL
Hi Scottie
Cement in place first so the cement softens the plastic, then either use a heated pin held in a drill chuck and work at it that way, or a pyrogravure, see I am now speaking French.....
Mike.
Scottie those welding details...wow that is something i can't wait to see MMOORE... ;-) :-)
Steve, I will have to have a practice on an old kit with the worms.
Mike.
Mike, That's the way I do it with the sprue I will have to practice the putty method.
Thanks Greg they are far from perfect but hopefully they will look ok when painted.
Another method - Duro worms, smeared with a little petroleum jelly after sticking worm to model then piece of small bore metal tubing with the end cut to a C shape to press in welds
