Hasagewa 1/48 SH--3H Sea King converted Royal Navy HC4
Thank you will look at getting some
Not sure if you know but a hot air gun is used to send this stuff off.
Been using an oven glove, good quality, to hold pieces to tighten the joint together..
No mate I wasn't aware can you use a normal soldering iron to apply the heat or a little blow torch?
The idea Paul is low heat. With the brass with high heat it might buckle. I use a Dremel heat gun Model 2ooo.
It uses a butane, lighter fuel. It comes with a nozzle for use as a heat gun on low temp solder. Also has an adjustable
heat slide.
Worth having a go with a soldering iron to see what happens.
One thing is you can get the paste into small areas where you may not get the soldering iron. The heat gun is not
a problem as it is just a matter of heating the metal which sets the solder off. Some of the small parts I have soldered
I do not think you could have got the soldering iron into
heat slide.
Thanks again I will get some and give it a go.
Bit of smell Paul & perhaps some not nice stuff. So I use my paint nose filter thinghy. Also in future a small desk fan to blow away from my nasal area.
As it, in my case, is only minor sessions I cannot see any problems. Electronic engineers are using this daily so would appear the risks are minimal.
Like all things better safe than sorry.
Oh thought I'd arrived at some metal ware forum.:surprised:
Great work Laurie, some thing I can enjoy looking at , but not able to attempt using solder.My limit is CA ,it probably wouldn't acheive some of the structures.
There are some nasty things in some low-temperature solders.
Yes I have had a look Pete. No lead though & there is only about 10 secs in an operation.
Interesting thing all the stuff I have read & not one should be careful you should do this do that.
Laugh oh laugh ;) John. And there is more to come & very enjoyable at
least for me :smiling6:
As mentioned on here the first SeaKing I built is in the archives here.
On that PE from FlightPath I did use C/A. This is my first go at low temp soldering
Does a better job than C/A but it is marginal.
Its an education in its self Laurie. Keep it up.:thumb2::thumb2::thumb2:
More bespoke work Laurie,You are a master with P.E,I used to do afvs and aircraft and i was hopeless with using etch sets.Have the most clumsy hands in Christendom and i admitted defeat.I shall just sit back and enjoy your Seaking coming to life.
Great stuff.
Richard.
Wow & at my octogenarian number of years John.
Life in the vintage dog but a bit ponderous. Needs
a lie down between PE. ;)
Great stuff.
Richard.
Thanks Richard. Well at the end of April a define lull.
I have the bent finger syndrome. Told it is a Viking thing. Fascinating
as my maternal grandfather was a Shetlander.
Not my finger but that is what has happened. Very difficult getting gloves on.
Fortunate I am left handed the bent finger right handed.
Just wonder what it is like for 3 weeks with just one hand. Just have to rope the
missus in ha ha.
Some amazing detail work going into this Laurie, very impressive.
I'm glad to see that winch looks nice and sturdy too, my brother used to depend on it!
