Evening Again Good People,
Just a small update tonight as you can see I have been busy with some research and good banter….
Dude 2, That's a great idea John!!! At least the crew wouldn't go hungry…..
Paul, Thanks my friend and there is a bit more to come, I hope???
Pete, Thanks Sir, what would I do without you!!! I forgot again today...…………...
I am moving onto the side skirt portion of the build which is also a very tricky part too. The skirts were modified and mounted so they would move when the StuG drove up or down on the terrain. This offered a little more protection than if they were fixed in place like most of the StuG IV's. A reference pic of them,
Ok, so this poor StuG took 2 shots and was put out of action. The swinging skirts took a beating too, but you can see that they only had one attachment/pivot point and that was on the top of each skirt. There were 5 skirts per side...
I had to do some drilling to bring the Dragon pieces up to snuff. I could have purchased the Voyager PE skirt set, but my luck with CA lately has not been the best (plus I'm cheap at the moment). I also needed to make 10 pins to hold the skirts on,
The mounting pins were drilled out with a 1.0mm drill bit and then drilled through, top to bottom with a 0.40mm drill bit. the U shaped wire is from an old set of Friul tracks and is easy to bend. These will hold the skirts in place when the time comes. They still need a little tweaking….
Short and sweet tonight!!! I do hope to get more done tomorrow. Thanks again for looking in and take care.....
Bleib Gesund
Allen
Bleib Gesund
Allen
