Conversations
boatman
christopher
NORFOLK UK
HI ALL how do you go about deltetin all Conversations ? as im gettin a lot built up
chris
If you look at a conversation there is a 'leave'' button at the top.
If you click that, you get the following popup.
That may do what you want.
UPDATE. Found a way to do all
Beside each conversation is a box.
Put a tick in it.
Then at top of screen is
and at bottom
That should work.
HI Gary well it worked once with the little blue box an yes a con went but now the blue box wont come up again thanks for your help but i'll have to keep tryin
chris
Why would you delete them? Are they in your way?
HI Jakko no not in the way just I was told havin to much on a pc makes it run slow so I thought id delete the messages
They aren't on your PC, they are on the server.
It doesn't delete them on the server, just hides them from your view.
Like Gary also said, the messages on the forum aren’t on your computer but on the server that the forum runs on. In any case, messages like these, and e-mails as well, take up so little room that you wouldn’t gain anything meaningful by deleting them. It’s bit like saying: “I need more space in my hobby room!” and then clearing out half a dozen drawing pins to make that space :)
OH THATS good then they are not on my hard drive then many thanks gary
chris
Like Gary also said, the messages on the forum aren’t on your computer but on the server that the forum runs on. In any case, messages like these, and e-mails as well, take up so little room that you wouldn’t gain anything meaningful by deleting them. It’s bit like saying: “I need more space in my hobby room!” and then clearing out half a dozen drawing pins to make that space :smiling3:
AN Many thanks to you too Jakko all clear to me now cheers guys that a load off my mind as my pc has been running slow an I done a defrage but as im low megabyte area it might be to do with the web bein busy cheers guys
chris
If you’re wondering how much of your computer’s storage space is actually in use, you can find out easily. This article explains how — it shows you where you can see how much room is still free, both in numbers and as a bar that indicates in blue how much is used an in grey how much is still free. As long as you’ve got at least a couple of gigabytes (GB) free space, you shouldn’t need to worry, I’d think.
Many thanks Jakko I had a check an it is hardly anything on the bar about 1/8th of an 1nch of a 2inch bar so that means ive loads of space well with this tiger build I think i'll need it cheers for your help that's something eles ive learned today :thumb2:
Very few laptops today will have problems with storage unless you do a lot of gaming or photography and store everything on the laptop.
I have a laptop with a 128GB SSD drive in it that I can run most things on and is barely using 60GB.
I store most of my photos online, or on my external storage devices ( in my case a small file server ) as my internet is still in the dark ages as BT refuses to upgrade the lines or install a green box anywhere nearby.
