AH GOOD Del glad you got it sortedYOU SIR, are a star.
Faulty switch, so I shall bypass!
WELL Done chris for sorting out dels leds you the manAt least we know it’s not the led’s!
I would examine that switch and try switching the sockets round before binning it.
It's not well made so it's just as easy to pop a battery out tbh..At least we know it’s not the led’s!
CHRIS more than sometimes you helped me on my mouse arrow an now its a lot easyier to spot so keep the good advise cominSometimes I have a use!
DEL you ca buy tiny switches from componets shop online an then all you have to do is fit it in the red wire so its a make an brake so on an offIt's not well made so it's just as easy to pop a battery out tbh..
Very true!
I’m sure boatman chris has a switch laying around....
That's incredibly kind of you, message on route!WELL ive got a switch to spare Del as long as you will ues it an its a very tiny one about 4 mm long an you can have it if you pm me your address as i will send it in a tiny envolope just say
chris
HI Del ive posted the switch to you this morning an its on it way to you an when you get it after youve soldered on your wires do not try an c/a it as it will get glue in it an become no good best idea i use with these tiny switches is cut a tight fitting hole in a bit of plasti card an just press the switch in place then glue the plasti card to the ship where you want it chris
Cheers!Looking good Del
Nice looking deck!
My first ship build will use a wooden deck so very interested to what they are likeCheers!
