BattleshipBob
Hi Gerry, what a interesting build, way past my skills!!
Thanks.Looking excellent and a cracking idea, Gerry.
Just be aware of complicating things. Simple is good.
Ron
Hi Bob, sorry I missed your post last night.Hi Gerry, what a interesting build, way past my skills!!
Thanks Richard, only way to learn something new - I'm just bumbling along combining things that I have done with things that I haven't tried before - the water/pva/tissue/cardboard build is something that I've often used in the past to make things - what's new to me, is/will be the use of the coffee grounds, creating the water effects and the campfire and smoke, but if I don't try, I wont know if it does or doesn't work! :thinking:That's the way to do it Gerry, go where no man has gone before...explore and that's the fun with dioramas, being able to replicate things in scale from scratch and everyday stuff.
Too true, and his work with the clear silicon - I'll be using both techniques, as I'm planning a small stream that comes bouncing down rocks into a pool, then bouncing out of one of the sides - if I can do even half as well as he does, I think that I'll be happy!Ron is the resident expert on using varnish for water, always looks good.
Nor have I, :tongue-out3: but there's got to be a first time for anything new - luckily, I've a very nearly new tube of clear silicon that I had to open for a little job, so plenty to play about with, but will have only the 'one shot' at it when putting it onto the dio, as I think that it'll stick like the proverbial to a blanket. so at the moment playing with different 'sculpting' and painting techniques, then it'll be play with working it at an angle & in small spaces - so quite a way to go, might have to get another tube!!!:thinking:I have never attempted moving water......this should be interesting. Rick H.
So am I :tongue-out3: :smiling:Gerry,
This is really looking good I am interested to see how the water turns out.
Get the pennies ready Rick and I'll get my little piggy ready. :tears-of-joy:Sounds like a reasonable approach Richard.......remind me to pick your brain when I get brave enough to try this moving water scheme in the future. Press on Gerry.....you have lots of support :thumb2:
Rick H.
Dan,Gerry. Firstly, 10/10 for bravery. Moving water is something else. Kudos.
Not for one moment assuming that you aren't aware of this gentlemans work, I thought it'd be worth a look.
To be honest I'm not saying it's perfect but he does have some really nice touches.
