HI Benjamin i think it a light green but other may say differntHey. I bought the eduard spitfire and use tamiya color. What os the color for the kockpit?
Thank you. It is kockpit green i should go for?HI Benjamin jeg tror det er en lysegrønn, men andre kan si annerledes
chrisb
Yes, that's the colour you want.Thank you. It is kockpit green i should go for?
WELL hi Chris but i cant give the gent a correct colour number can you or anybody ? an benjamin where do you hail from if you dont mind saying ?Yes, that's the colour you want.
Norway. I dont think its an problem to that you know thatVEL hei Chris, men jeg kan ikke gi mannen et riktig fargenummer, kan du eller noen? en benjamin hvor kommer du fra hvis du ikke har noe imot å si ?
chrisb
Yes. I think so, it looks like that is the the best option. ThxJeg tror XF-71 Cockpit Green sannsynligvis er den beste for det du er ute etter Benjamin.
Geoff.
