Scotties Krupp Protze Kfz 69
..... 'ang on a mo !!
.... I thought you were doing a Krupp Protze Scottie?!!...
It can't be, because it looks SO different from the one I did ?!!....
...OH,I see.... ;) !!! .......
Has he displeased you Andy ? Shall I fire up the turntable and get the headphones and restraints ?
Great work Scottie. Much improved details.
Jim, thanks to be fair it's not difficult to improve on the detail as the kit is showing its age and is very simplified.
Some nice improvements happening :thumb2:
Mark, thank you as I said to Jim its fairly easy to improve an old kit.
That is sharp Scottie, really sharp.
Cheers Tim.
Bling bling :smiling:
Mick, sounds like an old phone. :smiling:
Cheers Rob.
Very nice Paul. Love how these old kits can be brought right up to date with some quality extras and some creative scratch work. Top notch building work:thumb2:
Los, I agree mate, I would rather get a cheap old kit and have fun hopefully improving it than spend a fortune on an over engineered kit that leaves little scope for tinkering.
I have no idea how you do that scratch thingy but it's superb Paul
Bob, thank you but there are far better scratchers on here than me.
Just beautiful!
It's a joy to watch you work your magic every time.
Neil, you really are to kind mate thank you.
Andy, lets hope it still looks like a protze when I'm finished.
Looking good Paul, all the extra work we have come to expect from you making a big difference.
A little more tweaking, the moulded springs were removed as were the swing arm pivots and replaced with some springs from the spares box and some pewter.
For strength the lights and width indicators etc had the plastic removed and replaced with wire, as was the turn flag arm.
Just for a bit of interest I hollowed out one of the headlamps to show some damage.
It still needs some tidying up.
cheers
Scottie
Hi Scottie
Good idea to replace the springs. Are they 'real' springs or did you wind wire around something? Replacing thin styrene with wire makes sense. The plastic always snaps and cleaning up mould lines takes longer than cutting a bit of wire. I've seen the broken headlight idea before - it looks good though.
Hi Scottie
Jim they are real springs, originally I was going to try and rework the suspension so it was moveable but then sanity took over.
Absolutely amazing scratch building…like I said another masterpiece on the way
I've come in a bit late for this, now seeing what might have been if I'd have been a modeller doing mine!;)
Brilliant work on this Scottie! Loving the work that you're putting in on this :thumb2:
That damaged headlight is the biz Paul ! Will remember to steal your idea for a future build ! ;) Really love that rear suspension too !
Just zoomed in on the mirror - what size spanner did you use to fix it to the stem??????
The truck is pretty much finished now. the canvas door covers have been added from some left over PVA/paint mix that I had made earlier with some masking tape straps. The windshield is also done and fitted. The rear superstructure is just dry fitted.
The rear mud flaps are doubled over masking tape with the metal detail added from the etch. I always think the etch mud flaps are to rigid so this way they are flexible.
cheers
Scottie
You're still at it - showing your wonderful attention to detail. It's often said when a model has loads of scratched and PE detailing that it is almost "a shame to paint it" - true in this case.
