Time for a change
Steve Jones
Hi everyone
For those of you who follow my work know that I am Vallejo through and through. However I am fed up to the back teeth with the short shelf life of these paints and acrylics in general?? The reason I question this is because I do not know if other acrylics suffer like Vallejo.
Basically I do around 6 weeks a year of acrylic airbrushing so paints will sit in my model room for 6 to 12 months before I use them again. When I do the paint is full of lumps that block my airbrush no matter how much I thin them down or mix them. I certainly do not want to go down the road of straining out the lumps of paint before use.
I dont really want to move away from acrylics so do you get the same problem with other acrylics??. I am not interested in using AK, Lifecolor or Mission Models and I presume AK 3gen has not been around long enough to find out.
If I have to move away from acrylics then I do not want to do enamels. So I assume acrylic lacquers are my next and only other choice??. I have used Tamiya in the past and have been impressed but did not use them due to the limited colour range and I find them a devil to clean out of my airbrush. If there are answers to these issues then I am willing to revisit Tamiya. I am interested in peoples opinions on other acrylic lacquers like AK etc. My main requirements are paint flow through airbrush including shelf life, ease of cleaning airbrush and colour variety. So with all that information and questions I look forward to hearing your opinions. Many thanks in advance and happy modelling.
Ive had the same issue with vallejo so interested to see what pops up here.
Have you considered Mr Color. I like them.
Best AB cleaner is Premi-air Liquid Reamer.
No I havnt Jim. I will look into them and get back to you. I use Reamer for getting out the stubborn dried paint but I was hoping to continue down the easy route of water for most of it and then a clean through with an airbrush cleaner. Speak soon my friend
It seems they are the same as Tamiya but have a better range of colours. The pots are 7ml less than Vallejo for the same price. Can I thin them out to make them last longer Jim? Have you had any experience of them going off like Vallejo? Will I be able to brush paint Vallejo on top ie detail painting? Can I clean them out with water or do I need to use airbrush cleaner? Certainly look a good option though
My usual paint these days is Mr Hobby Aqueous, which is an alcohol/water based acrylic. They have a good range of colours
Just had a look Pete and they certainly look good. With the alcohol content does this stop them drying and clogging the airbrush over the longer term?
Hi Steve, hope you are ok
I really like Mr Color, sprays so well and drys quick. I thin at 50/50 but have also used 60/40
Must be cleaned with liquid reamer and Mr Hobby cleaner, no issues apart from it does pong a but lol
I've not had any problems Steve.
My experience with Mr C is the same as Bob's. I've not found they go off and some are 4 years old. No ab clogging but does need a solvent cleaner.
Bear in mind there are two Mr Hobby paint ranges. A Tamiya like acrylic which Pete mentioned and Mr Color which is lacquer based.
Hi everyone
Don't ever change mate....
... I love you just the way you are :)
Pete, Jim and Bob - I have looked into the differences and I am starting to sway towards the Aqueous. It seems I can use all this Vallejo cleaning and thinning bottles I have with it.
I've used the Mr Color lacquer, and it does spray really well, but it stinks, needs their Levelling Thinner (the standard thinner seems to give tip drying) and a strong cleaner like Liquid Reamer or Mr Hobby (or is it Mr Color?) Tool Cleaner. The Mr Hobby Aqueous cleans with IPA, water, or the Spraycraft cleaner that Hobbycraft sell.
Yeah thats what's making me sway towards Aqueous Pete. I used MRP once and it was awesome but I had a blinding headache and it stunk the house out
The aqueous range is in some ways the best of both worlds. Good colour range, only a slight smell and that's the alcohol, easy clean up and sprays better than a pure acrylic.
Invest in a few colours and see how you get on.
Never tried the aqueous, and yes had to check the spelling lol
Kindly let us have your feedback Steve
Thats what I am thinking Jim. As you know I hairspray chip practically everything I do, so I need to see how that works out. Also how does it react to my weathering techniques. Looking a worthy choice to try.
