Rick's 1-87 Scale ROCO Ju-52m Medical Transport
Great stuff so far Rick!!
I've always had a strange fascination for these crude looking things, looking forward to seeing it develop :)
Great cut out Rick, hope you are well and not under a load of snow .
Thanks guys....this is one of those projects that is a plan as you go sort of thing. The interior that has now been exposed, needs a little TLC in the derail Dept. I don't have anything remotely resembling the corregated skin, so I'll be winging it with just the stringers and frames and hope for the best. Cheers and thanks for the input.
Thanks Scottie, wish I had more progress to show for my efforts.... it's gonna be a haul, but I'll get there eventually. Good to hear from you. :thumb2:
You used to be able to get 1/87 scale corrugated (real aluminum) skin from Walthers.
I'll get in their online catalog and check ..thanks for the tip Paul. :thumb2:
I got the rest of the floor in ( all that I'm going to do anyway) and all the support bulkheads in place (aft) the forward cabin divider is in place and you can make out where the casualties will be "racked" up on either side. I will not be attempting to build the entire fwd. cabin and such as it will be mostly invisible with the fuselage overhead in place. P1012510.JPGP1012509.JPGP1012512.JPGP1012514.JPG
Acting on Paul's suggestion, I found a couple of different brands of corrugated material. None of which were suitable for my purposes. So I gave up on the idea of running stringers and skin on the interior. There won't be that much visible when this is buttoned up anyway.
Thanks Lee, I just finished scraping off the molded in exhaust system on the #2 engine and will be scratching that as well......stay tuned. ;)
You bet seated and watching but John has that Crazy look on his face again get the Fire extinguisher ready.
Yeah Lee......He's been playing with that "Buzz" Box (arc welder) all day, I'm surprised he hasn't set fire to the whole shebang over there at Race Towers. Better call Matron to have a look at him. :thinking:
I’ll get right on that Rick.
So here's the latest, I have used the removed plug to fabricate the upper cargo door as the back side will be visible from the other side of this bird....the bottom door will be scratched later from strip styrene as it won't be visible from the bottom unless you pick this thing up....going on a base so who cares. finally got the scratched exhaust ring and stacks located and the prop and cowl on Royal PITA.....sorta like holding down an Octopus while administering an Enema!! :tongue-out3: :rolling: P1012517.JPGP1012518.JPGP1012516.JPG
Quite safe re the fire at the moment guys, I've just had my meds courtesy of Matron .
Rick think something to judge the scale you work with would be nice , as the detail is remarkable .
