Metal Spitfire Mk 1
Modler bob
Member
I have a diecast mK1 spitfire @1/24th scale (I think) that I bought years ago.
the engine cowlings and gun covers are removable, which meant that over the years they have disappeared through my grandchildren's sticky fingers :flushed:
just wondering if you guys might have some ideas on fixing this.
You could try to replace them with aluminium sheet, a roll of thin should do the trick and can be obtained from Azon or on evilbay. And is easy to work with.
Mike
What about a foil takeaway food container, or would that be too thin?
How about a photo Bob.
Yes, probably too thin Peter, needs to be about 1mm thick. thanks anyway.
When time, I'll search around for Mike's suggestion of a roll or sheet
I'll get a photo up as soon as I can. :thumb2:
Maybe used a piece of a used tin can from baked beans etc? Cut to shape and will hold it once bent.
I have some pewter sheet of about 1mm that may suffice somewhere in the chaos of my cave, if so give me a heads-up so that I can alert International Rescue to come to assist me in locating it!
Great stuff Steve.
Once again you've come to my rescue
Let me know the cost/postage etc, please?
And I'll PM you my address. :thumb2:
I wish I had room for a cave :smiling2:
Bob
Great stuff Steve.
Bob
Just send address via PM Bob - no charge, life's too short for swapping pennies!
I now have a sheet of Pewter to hopefully fix the Spitfire.
All thanks to Steve (Airborne1)
