rickoshea52
Mmmm, that would figure as the top, (in the image), is the exact diameter of the circle where the rotor head sits! I'll have another check of my plans but I have read them over a few times and it never jumped out at me!!They are mounts for a separately available motor.
I'm sure it was mentioned in the instructions on the one I built. You have to leave part of the interior out to fit them.
Many kits’ instructions include drawings of the sprues and indicate which parts are not for use with the kit you have. It would help a lot if every manufacturer did this, as sometimes it can have you quite puzzled even if you have a lot of experience with these things.Also no mention of the two parts in the destructions.
Many would say so, yes. Definitely bookmark material.By the way. Is Scalemates a good source of information re plans etc?
Hi Rick, (@rickoshea52 ) I have managed to source the squadron badge. It was a good exercise in procurement!!!!As far as I know they were 78 sqn. During the conflict 202 sqn provided SAR at Ascension Island and may have gone to the FI in the immediate aftermath but I can be certain.
If you have the kit with the grey Sea King on the box with a yellow and black stripe along the fuselage side then you have the 78 sqn decal included. It’s a yellow lion rampant on a black disc.
If you don’t have this kit I’ll see if I have a spare to give you, I have at least two of these kits.
The last build steps in the instructions include these parts. They for a motor as mentioned.Mmmm, that would figure as the top, (in the image), is the exact diameter of the circle where the rotor head sits! I'll have another check of my plans but I have read them over a few times and it never jumped out at me!!
SOP for winchmen. One must pose for the cameras. (Even when it was frowned upon at the local nudist beaches - Studland Dorset)I'll grab a seat please . Think I'll sit with Andy then he can explain the finer points as you proceed .
I remember when I was a mere youngster on the beach at Frinton waving to the winch man as they flew along the beach in their yellow SeaKing. He would stand at the open door and wave to people on the beach .
:thumb2: I just knew someone would bale me out with a handy tip! Cheers for that. I did think of using Maskol but then the thought of trying to remove it all from the fiddly bits!!! And it'll be something else I've learned. Cheers for that. I did experiment with masking tape but!! I'll leave it there. A fail!!Instead of repainting the wheel wells after airbrushing the hull, you could just stuff them with wet tissue.
Thanks Rick, I had actually forgotten about that!!! (Doh).Don’t forget the green tinted windows above the pilots. I used Tamiya clear green on the inside so you get the shiny clear finish on the outside.
