On another forum, a group build that ran until today had the theme of “movement”: build a military subject so that it gives the impression of motion. I wanted to join but had no real idea what to do with that in a way that wouldn’t take ages, but eventually got the idea for a modern tank gun projectile while it’s in the air — hoe much more movement could you want?
After finding some photos and drawings, I decided on 1:12 scale because that meant I could build it around a length of 2 mm rod:
The nose cone is from a 1:35 scale tank gun round, the wire is copper and the fins are 0.25 mm plastic card. The whole thing is fitted to a length of 0.4 mm spring steel wire as a stand.
But this isn’t movement, so I took a Games Workshop “biker” base and glued plastic card over the top:
Followed by semi-random pieces of plastic strip:
View attachment 484148View attachment 484149
Once the glue had dried, I cut and filed the overhanging parts to conform to the base shape and painted everything:
View attachment 484150View attachment 484151View attachment 484152
The projectile is silver with Tamiya Smoke over it, then matt black for the nose and tail. The base is an earth brown with some sand-coloured areas (deliberately not covering well), then a layer of Army Painter Soft Tone for shadows and a quick drybrush with sand; that done I painted two bits of strip green, added a wash of Army Painter Green Tone and a yellow-green drybrush, and finished
