Thanks Jim.It's looking more and more tree like and following your progress is very interesting.
Don't get a large bottle, I did , only used some and the rest even with the top on went hard. That Flexi Bark sounds good , I've used straight latex before for tree trunks .Depending on how well this works, I might get some liquid latex to use as a finishing coat - it should tone down the bobbliness. I think the Flexi-bark™ is basically liquid latex with a fine texture added, possibly ground cork powder or something similar.
Thanks for the advice, John. I'm now thinking I'll give the latex a miss and see how it goes just with Flexi-Bark. I've put on a layer over the foam clay and I'm really pleased with the effect - I'll post pictures once it's gone off.Don't get a large bottle, I did , only used some and the rest even with the top on went hard. That Flexi Bark sounds good , I've used straight latex before for tree trunks .
Thanks Stephen.This all looks very, very good!! I love how you cut all the base terrain! Very inspiring! Please, keep up the good work!
Thanks, Jim. Misting with a brighter green will be the way to go, as you suggest.That is really impressive Paul. Very realistic. If you did feel the need to "lighten" it just airbrush a mist of lightish green from above.
That's a common issue I have, not just in dios but in kit building. "If I glue this can I still paint that?" "Will this part prevent me fitting that part?" You are right in that you just have to go for it.It started when I couldn't decide on the best order of assembly - every option compromised some element of the build,
