M10 LEND LEASE BY ACADEMY 1/35 AMBUSH .
Thought it tasted different Wibble , thought it was water. :smiling3:
That's what I said one night after a night on the booze, though I had a slug of Teachers, no it was a slug of aftershave.....
Hi , been slowly getting there.
Still loads to do, figures are coming along slowly.Looking fwd to the actual diorama part .
Thanks for looking in .
John .
Coming along very nicely John,:thumb2:,
I've always had a liking for "open top" tanks,spgs :cool:.
Hello , some photos of the figures, pleased as these took some time.
No the correct amount in the box as a photo showed, but it looks better at this size.
Very cramped, and quite had to get them into the turret.
The Germans , ready to set the ambush.
2022_10_cROP 1.png2022_5.jpg2022_6.jpg2022_9.jpg2022_12.jpg2022_14.jpg2022_20.jpg2022_15.jpg
Now the M10 and these figures are done on with the best part.
John.
Crickey! You’ve been a busy boy painting that little lot :surprised:
Splendid job and I see you’ve even got markings down on their helmets….impressive!
Lovely stuff John
Thanks Neil.
Very nice John, a fine bunch of lads.
Cheers Andy.
Excellent work with the figures John.
Thanks Jim, really enjoyed doing the Germans .
Yes even managed those very small decals Si. Used a piece of plastic card. Placed the decals on and them a couple of drops of water from a pipette . That way they just came loose , picked them up with the tip of a small brush and put them in place .
Very, very, very late John
Have a chair, will squeeze in at the back?
Always a seat for you Bob down the front . :thumb2:
Meant to mention the tracks, for me a length like that is great. However they do NOT like paint , well Acrylic anyway . I sprayed them with a track AK 3d gen primer, it all came off , sticking to the road wheels . Some thing to think about for anyone with this kit .
Just your luck John! You get a kit without individual tracks and now the paint won’t stick :tired:.
Well if the paint won’t stick, Bring on the mud!!
Hi Si, hope you and all at Benson Villa's are well .
Strange track mixture, even read it somewhere..
Started the best part ( for me ) .
Starring with the XPS form sheet , cut to size after marking in with tape free hand on the hot wire cutter , then to gain depth added a slightly thinner section.
Cutting up a 50 mm thick piece roughly in half gave enough material to make the front for a building and the raised area .
When gluing I use a piece of grease proof paper to protect a clean cutting mat.Usung Deluxe white quick drying glue held down and together with steel bars .
Although recommended to use the white glue I'm not convinced as the section above was still unstable 3 hrs later. Is a 5 minute glue on timber and paper ,but not on the XPS.
Leaving the rest to dry I cut a piece of Kapa foam board for the stone sets.
Well worth the cutter and rail for a perfect 90deg cut.
This is now stripped of one face of the backing paper ready to imprint stone sets .
The cut out section on the bottom right hand front will be a large creater, this will be deep enough for some of the Germany ambushers to hide in .The others will be in battle damage opening in the building behind the M10 .
Thanks for looking in, comments are welcome .
JR
