Dragon 1/35 sd.kfz.184 Ferdinand
In between taking little one to a birthday party, the weekly shop and a trip to the local model railway shop with the bigger little one….managed to get the base paint on.
Not much bench time for me this week but managed a little today and began masking for camo scheme….
Looking good Si. Masking looks fiddly. I don't mind masking up but I hate removing it. Too much stress to see how much bleeding under the tape there is. I'm sure yours will be fine :thumb2:
Cheers Jim,
Ive been going round the edges of the tape with one of those silicone tipped brushes, rubbing it down firmly and I’m using bits of blue tack where the tape meets a tricky area so fingers crossed I don’t get too much bleeding under the tape :thinking:
Cheers Jim,
You probably know this trick Si, but Squirt some of the base colour first, so if there is any bleed it doesn't show.
I do love a bit of fancy masking.
You’ll know only too well it’s all in the prep with masking so I’m using my best concentration face when applyin…..
View attachment 496474……:smiling5:
Pete, turns Out I didn’t know that trick so thank you kindly, I’ll be sure to try that :thumb2:
Blimy Si you had me thinking for a bit rember the little zvezda 72nd one I built ,couldn't remember using masking tape or silly putty (hope you don't mind a pic)
Then the light went on i used masking fluid pretty sure did the whole thing yellow masked up with the fluid and squirted the green looking back now would have made a better job the other way around still looks like yours is a bit big for this way of doing it ,good to see it making it way to the airbrush though. Is the little bison next up ?you do realise I won't stop haggling about that one. Dave
They’re not the same, Porsche Tigers had their own unique type of track. Jagdtigers had two different types, one from Porsche and the other the same as on the Tiger II, depending on the suspension fitted.
thats good to know (although I was making no quotes) as the Dragon Jagdtiger track links look crazy:
Hi Dave,
I did like your 72 nd elefant/ferdinand, you made a cracking job of that :cool:
I had planned on just free handing camo but when I saw this scheme I knew there was no way I’d get it neat enough.
As to the Bison, well I seem to of misplaced it :thinking:……I got a little 1/100 Pz III on the go if your interested ;)
Thanks for all your positive feedback chaps :smiling4:
After a lot of blue tac and masking tape had been applied and much scrutiny, I had nothing left to do but get some colour in the airbrush and hope I hadn’t missed anything!IMG_1623.jpegIMG_1622.jpegIMG_1621.jpegIMG_1620.jpeg
To say I was pleased would be an understatement! It’s gone far better then I hopped :smiling4:
Barrel and wheels next…….
I’m now a little confused about Jagdtiger tracks, as the Porsche and Henschel vehicles apparently had different tracks (Gg 24/800/300 resp. Kgs 73/800/300) but I can’t tell them apart in photos — which isn’t too surprising, since the 800/300 in both designations is the width and pitch in millimetres. In any case, both consisted of two different types of link: a “main” link with guide teeth and aggressive pattern on the outside, plus “intermediate” links to connect them, like the instructions show.
Andy, Scottie et all…..thanks again chaps :smiling4:
With mojo flying high I headed back to the bench straight after dinner and got the wheels and barrel painted.
