Me, I usually rig with a slow 'medium' CA. But that's just what works for me, giving a bit of wiggle room
BTW I've seen it a couple of times, but what IS TET?
Tamiya Extra Thin (cement)Me, I usually rig with a slow 'medium' CA. But that's just what works for me, giving a bit of wiggle room
Thanks for that Mike. After the final coat of varnish today I again stripped it right down, literally!!!! left it for a wee while, then started cleaning again. Managed to pull off small pieces if drying varnish from around the parts that make up the nozzle.Airbrush... You need to strip it down to the bones. Leave it in a pot of IPA overnight and then go for a full clean. What has happened is that when cleaning the airbrush the varnish has thinned and not all been washed away. The air still coming out of the brush even though you have not pressed the trigger is the valve sticking. I have this still on a couple of mine and normally if it happens I just flick the trigger to the up position. With the valves I have cleaned them, replaced the rubber ring/seal, left them to dry for days before assembly and still it happens - I now let it dry for a couple of days in the airing cupboard, then dust it with a bit of talcom powder which helps most of the time.
Also check the needle because when you assemble and there is still a bit of moisture left, the needle develops a ring around where it joins the tunnel, again mine is left out untill I am ready to spray, but don't do what I have done on a couple of occasions, started spraying and wondering why all the paint is going over my hand and not on the model - and that is a clean up job.
OK, it's sat in a bowl of IPA, (covered). I'll attack it tomorrow and see what we get from an overnight soak.Airbrush... You need to strip it down to the bones. Leave it in a pot of IPA overnight and then go for a full clean. What has happened is that when cleaning the airbrush the varnish has thinned and not all been washed away.
Pleased to help, been through the pain of wondering what I have done wrong on many occasions.Thanks for that Mike. After the final coat of varnish today I again stripped it right down, literally!!!! left it for a wee while, then started cleaning again. Managed to pull off small pieces if drying varnish from around the parts that make up the nozzle.
Before SWMBO starts me on my Friday jobs, I'll strip it down again and soak for the day in IPA as you say than dry and leave it apart overnight.
It's only the varnish so in the future I'll cary out a full strip down and soak procedure.
Doug
Be careful what you wish for...All things being equal, I should be in a position to start on the decals tomorrow.
If it is fine weather, you know what that means - grass cutting...SitRep. AB has had a thorough clean. I even dismantled the mechanism where the air hose connects to the AB. Unscrewed a small brass screw, removed the spring and rod which depresses when you put in a demand for air!! Cleaned all that then reassembled!! The whole AB was then assembled and tested and all appears to be functioning as it should. Glad I don't use varnish every time I use the damn thing!!
All things being equal, I should be in a position to start on the decals tomorrow. (When I say all things being equal, I, of course mean, if SWMBO allows me time off for good behaviour!!!!!!) I did clean ALL the block paving today. AND. Replace the two valves on the kitchen tap. AND cook dinner. So by my reckoning - I'm in credit!!!
This is one of my more minor reasons for not wanting to use varnish unless I need to: you often can’t tell where the stuff has gotten to — and where not.Glad I don't use varnish every time I use the damn thing!!
Good question nicely phrased! Can’t recall seeing red!!Shouldn’t the tail rotor roots be pained red too?
