- Joined
- Apr 27, 2018
- Messages
- 15,019
Thanks Andy for your support along the way.You say you haven't done much, but what you have looks excellent.
Jakko I'm having enough trouble with this one lol.Or do a little bit more work and you can have the Dutch version :smiling3: Mainly involves replacing the smoke launchers and antenna mountings, off the top of my head, and swapping the AAMG, if you fit that, for a MAG.
Thanks mate. Getting a bit frustrated at the moment. It's my fault just detailed the front winch cable hatch to find that it is covered by the up armoured front panel.You ask if you should leave the top loose - nawww!!! let 'em get eye strain looking in the doors....
As for the rest of your work - brilliant as always.
I get the mojo slipping in and out, getting that myself with the Doher where I find sitting on my arris munching on a Magnum and shouting at the tv seems the better of two evils....
If I choose to build it without the armour it will mean a whole mountain of scratch work as everything on the front is designed for the up armoured version.
Or does anyone know if they just took what was on the hull off and bolted it on the new armour?
