Tim Marlow
Fascinating. Quite complex and sophisticated for something that looks like a shopping trolley with an engine on top……..As I mentioned yesterday, I'm having a rest from the build today - so far I have kept away.
However, I have touched on the wheels and brakes previously so I thought I'd expand on them.
The Wasps wheels fully castor for a variety of reasons. Wasps never ground taxi, in all my years working around them I have only ever seen one ground taxi and it never took off post taxi either. To taxi, you have to lock the rear wheels in the fore and aft positions. Each wheel is indipendat of the others. The two front wheels are then left un-castored! This allows it to steer. on the ground, exactly the same when manoeuvring without power. (IE being pushed).
If flying over land or with 12 nautical miles of land. The back wheels would be towed in 45 degrees and locked in that position. The front wheels locked fore and aft. You may now be able to see why ground taxiing wasn't possible!! The reason for this, as I touched on, the Wasp has no hydraulic brakes to stop forward motion. Just a parking brake.
So!! If the Wasp has to do a running landing for example in emergency. The rear wheels would act the same way towing in ski's work when on snow!! Exactly the same principle.
Pic 1
When over the sea, totally different. If you have to land in an emergency, landing in the sea, it doesn't matter about the rear wheels slowing the helicopter down.
At sea, operating from a warship, the rear wheels are towed 'OUT' 45 degrees. The front wheels are now towed 'IN' 45 degrees. This now allows the helicopter to rotate 360 degrees. Why?
Well, under normal conditions an aircraft will take off into wind. If this is not possible, eg, if the ship is under fire or has to remain on its non flying course for operational reasons. Then the Wasp will rotate on the flight deck and turn into the wind itself.
Also, if weapons, mainly missiles, are carried and armed then you don't want to be facing the ship and have one come off the rail!! Not good!!
To help with this rotating on the flight deck a 'swivel' is attached to the Wasp and then to the flight deck.
The Lynx uses a similar system called the harpoon which grabs the deck when landing. The swivel on the wasp doesn't have that ability.
Pic 2
A pic I took of HMS Rothesay's Wasp with my mate Kim casually dangling a leg!!! It shows the wheel configuration.
Another useful function the Wasp had to keep it on deck in rough seas was negative pitch on the main rotors. The pilot would 'push' the collective lever through a stop and literally push the Wasp onto the flight deck keeping it in place. Although I have been in one with neg pitch applied and we slid across the deck. Luckily the quick thinking deck crew ran out and banged lashings on before we toppled into the sea. (Scary).
That's all for today folks. Hopefully I'll get back to the little plastic thing tomorrow!!
Hope you have all fallen asleep!!
Doug
