The parts that are going to be blue, are now …
… grey
I wanted to do this yesterday, but totally forgot :rolling: So, I sprayed them today with some car primer. I suppose this attempt shows that that stuff is meant for metal more than for plastic, because it covered in one coat on the etched parts, but needed two on the plastic ones before it was a nice and even shade of grey. (The blue visible at the front of the seat is because that’s where it was covered by my finger as I held it for spraying. This is not a problem because the lower part of the seat needs to be painted black.)
The little mesh cover that will go over the air intakes was a last-minute addition. I thought the instructions said to paint it black, so I hadn’t built it yet. I noticed it has to be blue after I put the first coat of primer on the rest of the parts, so I quickly cut it from the fret and folded it into shape before doing the second coat of primer.
Now to find an aerosol with a medium blue paint. I found one that says it’s Himmelblau but the cap looks a bit lighter than what I think the Tyrrell should be. If I don’t find anything better, it will have to do, though. Unless the bottle of Tamiya XF-7 flat blue I discovered I also have, turns out to be usable still, which I’m not really expecting it to be.
… grey
