1/35 scale Centurion Mk.12
That's a stunning build Mike, it's coming along very well. I really do like that camo netting.
Thanks for the description of how you dusted up the hull, that was really useful. Just to clarify, did you spray the water/pigment mix onto the model?
Thanks for the comment Arnold.
I used a #4 soft brush or in technical terms a medium soft brush. and brushed on an area at a time, there is no need to rush because you can leave the mix to set for a few hours and come back to it. You just need to brush the mix on and move it around so it covers the area.
Just a bit more done....
Exhausts have been weathered, bazooka plates added along with the exercise panel (still to be weathered) and the fascine carrier now in place.
Next will be weathering the plough blades and 'ski's'.
Mike.
Ah okay, for some reason I assumed you sprayed it. Thanks Mike, not being much of an airbrush man that makes life easier. Thanks for taking the time to answer, it's appreciated.
No problem, my pleasure.
As the actress said to the Bishop - keep going love, nearly there.....
And so it is for this build...
Tow cables to be added, some stowage as per the original photo and a bit of artistic licence... British Compo boxes in the side locker....
The brown biscuit coloured box is for a 10 man compo ration pack, again British, none of your MRE boxes on this build.
The base is underway, simple and neat.
More later
Mike.
In the words of the late, great Tina Turner - Simply the best!
Sorry to be a pest. A couple of questions please Mike.
Do you have to seal/fix the Flory wash before the next step?
The VMS pigment + water mix. Is that very fragile after it's dry being that you've used only water? When applying the pigments does it affect the Flory wash?
Thanks
More later
Mike.
There will be a short pause, well maybe a longish pause whilst I go back and read all I have missed!! Looking mega good Mike.
What a catch up!! Bl**dy amazing mate!!!! The detail and modifications are truly superb and even a tutorial in the mix too!! As for the camo net - in another league!
Superb mate, you can't beat a 10 man ration box.
Compo sausages, fruit cake and bars of chocolate that will break your teeth, hard tack biscuits crushed up and mixed with Carnation to make porridge... These are a few of my favourite things......
Thanks
No problem Jim.
I applied the wash over a matt finish, this was left for a couple of hours and then the most of it was taken off with a soft brush and clean water. It was then left to dry overnight. This as you can see when comparing the before and after pics it really toned down that 'Dinky Toy' green...
The pigment/water mix was then applied over the top, and I then applied it on an area at a time so that I could work the mix into the areas i.e corners and leave the rest clear or just slightly dusty. On verticle surfaces I appled the mix and let it dry for about ten minutes and then with a 'fan' brush dipped in clean water and tapped on a piece of kitchen towel to remove the excess water, gently stroked down from top to bottom and repeated that as many times as required.
The mix then dries 'hard' and can be handled if required.
What I will do this weekend is do a tutorial on an old kit lower hull to show the process/stages, and post it on here Monday, as trying to describe something can be taken as different by another, as we all know.
Many thanks for all the comments, they as usual are most welcome and even more so is the fact you took time to review the build.
Mike
p.s. Build on hold at the moment due to SWMBO standing list in hand, first job is to re-grout with sand/cement the patio, the slugs are getting out of hand and being too noisy.
