1/35 Italeri sd kfz 234/2
Hey, I thought I'd add the latest update of my 234/2 armoured recce here, instead of on http://www.scale-models.co.uk/threads/sd-kfz-234-2-puma.31952/! :oops: :D
Hull assembly thus far:
And turret:
Still some cleaning up to do, and I've got to get some practice with my spray gun setup :confused: prior to painting this one - then I can start adding the accessories and bits n bobs...
I also have some ideas about a diorama too, so watch this space! ;)
I've got PE envy, lol so I've been looking at modding some bits to add.
Spent a little while searching for cabling info for smoke grenades and headlights without success, so came up with this:
Then I stumbled across a photo that shows the smoke grenades had just one control cable/ducting (it's not clear) Looks like I'll be redoing that bit then! :mad:
\ said:
Nice, what's your spray gun setup
Hey Dougie, iI's an Iwata Revolution SAR, with the 'Silver Jet' compressor.
Got it on eBay, as it was cheap, and local, not entirely sure what I'm doing - but I will need a siphon bottle at least before I can start practising, d'oh!
Sounds good, the siphon bottle will also be good for larger areas and allow you to see what your doing better with fine details. I have a gravity feed and I need a bigger cup at times, which you won't
