1/35 M70A2 Krueger MBT, Desert Storm, 1991
Most impressive work Jakko.
Thanks, and Paul too :)
I esp like the plastic rod frame over the mesh. What size it made from please.
0.5 by 0.25 mm Evergreen strip, most of it. The centre part of the deck is 0.5 mm plastic card, so I took strip half as thick for the frames so they would actually be visible as recessed parts :)
Brushguards installed:
And while I was in this area, I also built front mudguard extensions, as I doubt a tank in service would have flat ones like in the kit, and anyway the German prototypes have a tube welded to the top of the mudguard that seems to be intended for attaching something to the front:
The extensions are from 0.25 mm plastic card, formed following the advice of @MikeC by rolling a strip of the right width around an aluminium knife handle and immersing it into boiling water for a while before holding it under a running tap. The rest is more plate for the side panel, and strip for the lip and the hinges, plus some punched 0.7 mm hexagonal bits for bolts to hold the extension on.
I also painted the part of the hull behind the suspension arms, and the inside-facing bits of those arms, and then attached them:
You can’t really make it out in the photo, but I scratched a cross into the undersides of the four assemblies with the shorter arms (see earlier in this thread) so I could keep them straight and add them into the right positions (nos. 3 and 5 wheel stations).
Even though this tank will be finished in sand colour, I painted this part forest green because real M1 tanks in the Gulf War were that colour and then overpainted sand, so bits like these would remain green (aside from overspray, of course). There are photos of M1s in the Gulf with the front mudguard lifted up, showing green underneath, for example.
I made the side skirts, based on the design for the M1 Abrams:
The main panels are 1 mm plastic card, with strip 1 mm thick and 3.2 mm wide along most of the edges to give the panels the bulk of those of the Abrams as well. These don’t got all the way on the underside because on the Abrams, only the front couple of panels are made of “special armor” (Chobham) while the rear ones are simple steel plate. The “special” skirts on the M1 protect the crew and ammunition, so for the M70A2 I felt they would go to approximately the rear of the turret so as to shield the ammunition and fuel.
On the underside of the sponsons I put plastic card spacers, and glued L-shaped pieces made from Games Workshop sprue as brackets to the skirts to securely attach them to those spacers. A few bits of square rod provide locating points to glue the brackets up against from behind. That will only happen once the model is mostly painted and the wheels and tracks are in place, though.
Unlike the Abrams, I’m not going to depict these panels as hinged to open forward or back, but upward like on the Leopard and late German KPz 70 prototypes. I still need to make the attachment points on the hull, though.
The stowage baskets on the turret sides needed reinforcing bars, but I found it very difficult to make those from plastic card. Punching or drilling holes to fit the spacing of the bars was almost impossible, to the extent that it began to look like I would have needed to make at least half a dozen for each of the bars before I got one that fit. I began looking for another way, and this turned out to be surprisingly easy and guaranteed to fit.
I first cut narrow strips of masking tape and wrapped it around the bars, as tightly as possible.
Next, I flowed superglue into the space between the tape and the bars, letting capillary action form it into a “skin” that fills the gap.
After the glue had dried, I smeared putty into the same area, because the superglue doesn’t form a thick enough layer and leaves a noticeable hollow. The layer of putty needs to be thick enough that it extends outside the tape, to account for shrinkage.
Finally, all that remained after the putty had dried as to scrape it all off flat, flush with the edges of the tape. The tape itself also needed a little trimming here and there, which can be minimised by hiding the end where it won’t be in plain view. I did pretty much the opposite with the tape in the foreground, as you may notice in some of the photos above :)
Thanks. I hope you’ll appreciate this next bit of trickery too. :)
None of the four sights on the model have any kind of interior detail yet they do have a big opening in the front and a clear piece to cover it. On my model the missile tracker isn’t there, but the other three are. I closed the door of the gunner’s primary sight, since the gunner will be standing on top of the turret, but that leaves the two by the commander’s hatch.
There are some decent photos of these to be found online, but working out the details is quite tricky. After looking at them for a while, you suddenly clue in to the fact that this is because there’s a big mirror in each of the sights: the objective lenses are actually pointing upwards, with an angled mirror above them. Ideally, I’d like to have a mirror in there on the model too, but there just isn’t the space (or at least, I don’t have a good enough and thin enough material) so I decided on a visual illusion: build the lenses etc. both at the bottom and the back of the sight, then add a piece of clear plastic at an angle to represent the mirror. Sure, the effect isn’t exactly the same, but it will do in 1:35 (or so I hope :)). The clear bit isn’t there yet in the photo, because obviously these still need painting. On the small sight, the lenses are just bits of plastic card, on the large one I’ll use the headlight lenses from the kit.
Nice research. Looks tricky alright. PaulE
It was surprisingly easy, to be honest. I had been putting off building these for weeks, looking at photos every so often to work out how to build them, but not finding the confidence to do it yet, but in the end it turns out all you really need are a few bits of plastic. The small sight has a plastic card shelf at the top, a piece to blank off the bottom, and four punched-out discs: a large but thin one on each side, and a smaller but thicker one at the back and the bottom — that’s it.
The big sight has two bits of thin strip running up each side with a small bit of rod in front, the big ring (a slice of ±7 mm tube) on the back, a length of rod on one side of the window, and what I think is a a wiper motor from a bit of plastic strip and a random piece of leftover round material from a kit — this last thing built twice, once at the bottom and once up at the top to be the other's reflection. Again, that’s it (well, aside from another bit of tube and a banking plate in the opening in the turret roof that the sight sits over).
Here are the optics in place:
It’s difficult to see in this photo (easier on the real thing), but with the angled piece of clear plastic in place, it looks fairly convincingly like at the back there is a reflection of the lens on the bottom. Neither of the two is glued down yet, though, as I need to do some more work on the turret and I don’t want them being in the way.
Also the turret rear:
This is the kit’s stowage basket, with American-style antenna mounts and a wind sensor like that of the M1 Abrams, both scratchbuilt from sprue, plastic rod and card, and some punched hex nuts.
My i'm stunned, some great work Jakko , most impressive indeed.
Thanks, though as I said above, it’s not actually difficult work :) Largely because these pieces are so small, a few bits of plastic go a long way.
I’ve decided against using the @eddiesolo method for the anti-laser coating, because those weren’t in use yet in 1991 — photos of M1s in the Gulf War show plain periscopes, not pink-tinted ones, so the kit glass will do on these.
More scratchbuilding fun. Naturally, if the front of the turret is uparmoured with Chobham, then so would the gun shield be. I figured this would be a fairly simple wedge shape, as there is no room for a more internal shield like on the M1. Working out the shape of the side panels proved quite tricky, though, and the hole through the front was only slightly simpler.
Here are the basic parts:
First was the round bit, which will go around the plastic tube I already have sticking out the front of the turret. My father made this for me on his lathe, from some scrap plastic (a bobbin of some kind, I think) that was about the right size of 11 mm diameter. Unfortunately it seems to be polyethylene, which is hard to glue, but I’ve got a pen that will probably allow superglue to stick to it.
After that I built the sides with a bottom plate that you can see on the left in the photo, which was fairly straightforward once I had one side plate the right size and shape. I made the second one by tracing the first on plastic card and cutting it out, which left it a little oversize. I then clamped them both into my modeller’s vice and filed the second part down to match the first.
The angled front plates need a hole trough them for the round part, and this could be quite tricky to get right, because this will be part of an ellipse, not a relatively easy to draw/cut circle. What I ended up doing was draw a front view in Adobe Illustrator: just two rectangles and a circle. I then subtracted the circle from the rectangles, leaving a perfectly circular hole. Then all I had to do was stretch each of the rectangles to the actual height of the plate (real height rather than height in the front view), which also stretched the circle to the right shape and size. Printed them out, cut them from the paper and pasted that to the plastic card to get what you see in the photo.
With the holes cut out, the plates then looked like this:
They still need their edges bevelled so the tube will fit, but I’ll only do that when the glue has set on the pieces now I glued them into the mantlet:
View attachment 352097View attachment 352096
As you can see in the back view, I also added reinforcements from 2 mm square rod, to make sure the pieces stay where they are and won’t come loose when I begin filing out the hole.
Hi Jakko
Very good work indeed. All the research and scratching does you credit. Soldering and then bending the light guards has made a great job. The bars on the stowage baskets are brilliant - I would not have come up with that method in a million years.
Look forward to further top work.
Thanks :) The stowage basket bars show the value of thinking outside the box when the usual methods don’t work, if you ask me.
I’ve now got the mantlet filed out far enough that everything fits together:
The bits aren’t glue together yet, but you can see it fits very nicely onto the turret, meaning that for once, I got things to line up as they should :) I did discover that I need to remove a bit from the lower back edge, because gun depression is rather poor, and of course close up the top. Other things to do on the mantlet are drilling holes for the telescopic sight and coaxial machine gun, plus probably add searchlight fittings.
Here’s most of what I’ve got so far — all that’s missing are the side skirts, remote machine gun turret and two crewmen:
The gun barrel is from a Tamiya M1A1. I actually worked out where the trunnions should be to balance the gun on the real tank, rather than just sticking the gun onto the existing mantlet parts, and found it would need to go about 10 mm further forward on the model than it is here. The reason I didn’t put it that far forward is because of the much enlarged mantlet I built, which would probably re-balance the gun due to its weight being right in front of the trunnions.
You see the big cupola on the turret, with the hatch vertically open? That’s where the driver sits. This is what the station looked like inside the tank:
The main idea behind the MBT 70’s layout was that the crew could be best protected from NBC attacks by putting them all in the turret, as that would mean only one compartment needed to be shielded. The driver’s station contra-rotated so it kept pointing forward. It could also be locked in four positions: 12 and 6 o’clock and at about 50 degrees left and right (all relative to the turret), the latter two to allow the use of one of the side periscopes in case the front one was damaged. The main problem, aside from complexity, was that drivers got motion sickness exactly due to this contra-rotation, even though the designers had tried to minimise that by putting his seat as close as possible to the turret’s centre of rotation.
On the American prototypes, there was also a TV camera on the glacis plate, with a monitor by the driver’s seat, but this apparently didn’t really help much. The Germans didn't see the point of it, anyway, so their prototypes didn’t have it. I’m still debating whether or not to add it to my model.
