1/35 scale Centurion Mk.12
Morning Wibble.
Front row please, I can tell you from experience those engine covers were heavy .
Any trouble with the tracks please just ask ;)
Wobble
Morning Wibble.
Wobble
Morning Wobble,
Welcome to the build.
Yes, Have lifted a few myself, that's where I got the high squeeky voice from....
Not at the tracks yet, putting them off for as long as I can....
Wibble
Update,
I decided on the metal barrel, mainly because the resin one did not want to remain straight....
So the choice of putty to use. I have used Tamiya and MagicSculp before and with good results, but thoght I would use the Geomfix (original A&B) and see how that works out....
First the barrel was rough sanded to give the putty something to grip. It was then marked out with masking tape....
The putty mixed up well and with very little stickiness that you get with some of the other brands....
Then I used one of the sprue bags, some talcum powder sprinkled inside and a 6inch rolling pin to roll out the putty which I had split into three lumps....
And there we are, three nice thin sheets about half a mm thick, and not all will be used...
So - taking one sheet of putty I measured out the width and approximate length, (look away now) I then licked around the bare part of the barrel to wet it, why lick it? because I had forgotten to get some water and it seemed the right thing to do at the time, and in fact it worked as I did not have gallons of water all over the work bench and myself to clean up after.... So the middle went on first and then the two outer sections.....
Then using the shaping tools I added the shapes of material to the surface and finished off the texture by dabbing the end of a tooth brush bristles around the still soft putty. Now all that needs to be added is the securing straps and fasteners....
All of the wheels are now assembled and ready for a final clean up. I have decided not to use the interim idler wheel but use the later ones that look like the Chieftain ones but a larger in size (when I find them).....
And that is it for now - off now to do some turret texturing...
Mike
Update,
OK, let's get the elephant out of the room first....
Elephant....
Correct way to add the thermal blanket.... I modelled the open part of the thermal blanket as it would appear at the top of the barrel - wrong, when in fact it should have been at the bottom of the barrel - that has now been corrected....
Added the lifting handles for the engine covers and the 'rubber' barrel stops around the outside of the engine covers....
Now for these little burgers - those of you that have built the AFV Club Centurion in whatever guise it comes will have had the problem of the half moon pin not fitting into the slot, and finished up with a return roller - rolling across the bench like a drunk dog after a night out.... So here is my method....
First I cut of the pin so that I have a flat surface... The half roller is then placed into my tube roller....
Making sure that I have the correct halves to start with... So here is my half roller ready to accept the other half....
A dab of liquid cement and a gentle push with the metal roller that fits in the slot will line everything up - now leave to set, and may your rollers never be wonky again....
Other work carried out today was to fill a patch on the turret rear where the wire reel fits, hence no texture added, the left front bin added and filled where required... And on the hull the fittings at the rear and the rest of the final drive and track tensioner....
And that is it for today..
Mike
Most impressive Wibble.
Lovely precise work as normal.
I was concerned for your safety until I read it was only a 6" rolling pin ;)
wobble
Coming on very well Mike. Fine work on the barrel. Novel way to deal with the AFV Club wheels.
wobble
Wobble
I hid the 12inch one for my safety....
Wibble
Arnold, Jim,
Many thanks, they look better the second time around...
And the return roller idea finally came after ages trying to get them to fit together on the Cent ARV many moons ago....
Mike
Update,
Pic of the rear end and its additions
Next is the turret and the casting finish...
This will be softened even more once the primer and paint go on...
The barrel strapping is now complete...
Close up....
And finally for today the turret basket is underway - aluminium mesh instead of that awful plastic stuff...
Mike
