Thanks guys. The way things are going this is going to be a long one. I keep thinking of more and more stuff to add or modify :smiling5: Not a bad thing though I guess.
Had another productive day out in my wooden wonderland.
First job was to get a filter on the camo. A few drops of colour in some matt medium and a splash of thinner made a nicely tinted clear. It turned out a little stronger than I was aiming for, probably one coat too many, but I like how it looks and it seems to blend everything together well.
After this picture it got a coat of gloss ready for decals tomorrow.
Then I've been thinking of all different ways to make the wheels on the wreck look as if they steered. In the end the simplest solution won. I cut most of the locating pegs from the hubs, leaving just enough to locate the wheels centrally, then cut the mounting faces on the backs of the wheels at an angle.
Which meant I could now do this. A bit wonky right now as they are only held on by blu tack, but at least it shows I'll be able to pose them properly when the time comes. I might end up doing the same on the trailer rig.
Then I set about the bracing on the underside of the scratch built load bed. Nobody will ever see it but if a jobs worth doing etc. It doesn't match exactly but it's a fair representation I think, and the mounting points had to be in different places as the chassis for this truck is set up to have a 5th wheel coupling on it. Needs some tickling with filler but pretty much done.
Thanks for sticking with me!
