1/87 Hummel battery on the march
Wespe Models has a pretty good Flakvierling, for resin, w/brass turned barrels. I've got a couple. PaulE
Congratulations Paul on this multitude of verticals and figures, the scale alone is something else and you still manage to produce such detail. :thumb2::thumb2::thumb2::thumb2::thumb2:
Thanks Dzohn. Always appreciate your support. PaulE
Hi Paul,
just had a catch up on this.
OMG you are a busy boy! I can't comment with any knowledge of the subject matter but the workmanship and attention to detail is great!
I was very impressed with the infantry kit all separate!
A very nice trio of Wespes Paul. There are subtle differences on each one. Is that down to your alterations or are they different kits??
Thank you Steve. Yes, #s 231 & 232 are the same kit w/added details to make them more accurate. #235 was by the same company but was an ammo version identical to #241. I converted it to an SP gun by adding a Preiser 10.5cm artillery piece (the recuperator is slightly larger) minus its carriage, plus additional details. PaulE
Thanks Scottie. Almost finished up #230 security halftrack. Needs antenna & weathering yet. PaulE
Thanks Greg. Running low on mojo for this, so calling it finito. PaulE
