1/87 Wespe resin Diomond T 969 Wrecker
minitnkr
Trucks, trucks, trucks, I'm stuck on these for some reason. Been in the stash forever. Cleanup, glazing & some paint done. Working different tires, axles & rear suspension to provide some flexibility.
Destructions are deplorable, and less than useless. Researching rigging & winch details as some items are not represented. Understand now why in stash so long. PaulE
Paul .
No doubt you will beat it into shape, but disappointing that the distructions are useless, it's like it was an after thought. " oh we had better put something in ." " What " " oh anything "
Some nice photos there Steve.
John .
Thanks Steve, but totally different as 4tonner used commercial twin boom Holmes setup. PaulE
Paul,
These may help I built one of these a while ago. If you need any more photos let me know mate
Bless your heart Scottie, 60, 63, & 43 are excellent & just what I needed. Thank you. PaulE
Paul,
Already looks like you're well on your way. I remember the great job you did on rigging your shovel and clamshell. No doubt you will prevail on this as well.
Regards, Rcick H.
Hi Paul,
think your rear axle may be bent or loose - it looks like it has rear wheel steering :smiling:
Good luck with the rigging
Thanks guys. The beauties of resin Simon. Dimples to drill from. One of the reasons why I wanted to use the other wheels. Apparently I drilled these two crooked.
Thanks, I'll need it. The pieces to rig around are very delicate and not all represented, so some scratching will be required. PaulE
:thumb2:Great work Paul.
I love the way you chop and alter with such great outcomes.
John .
Thank you Dzohn. Added shim to bed to obtain correct height. Added winch, finished mud guards w/steps. Drilled holes for sideview mirrors & vaious grabs. Pic shows added articulated rear suspension.
Dandy instructions for discussion only. Box art, lower right, has incorrect rigging. My notes in blue.
Scotties pics will be big help. PaulE
Starting work on tow rig. Scratched in power takeoff and winch drives, used ROCO O/A tanks as the kits' were too small. Drilled many holes for cable routing & collected many bits/bobs for scratching/completing the ends of the booms on right.
Flipside
C&Cs encouraged. PaulE
The beauty is Paul when you've been modelling as long as you , you have such a treasure chest of spare parts. Bet you never throw anything away .:smiling4:
Must be a great feeling when you come across just what you need .
Dzhon.
Yes indeed. Two shoe boxes full of misc. stuff plus many compartments/drawers of sorted stuff. Check out the bench vise just to the right of the shovels & axes found in my model RR stuff. Just what was needed to mount on the front bumper as seen in many WWII photos.
I just luv your bench:smiling2: It's always the hive of activity but on a miniature basis. Terrific update Paul:thumb2:
Thanks Steve. A shot of the bench w/its' many distractions. Currently jeeps, 1/4 ton trailers & half tracks. Found some buys on-line to fill in some gaps + some much needed 2.5ton truck serial# decals.
Working Jeeps, 1/4 ton trailers & halftracks to fill vacancies in medical, engineer & armored infantry platoons.
C&Cs welcomed. PaulE
