242 squadron codes?
Alan 45
i have an idea for a BOB dio for next years 75th anniversary and I'm looking do an entire squadron on the deck and I'm trying to get the codes for all the fighters
Codes I have
LE , A
LE, D
LE, F
LE, X
LE, Y
I'm missing the last letter of the final plane in the squadron anyone have any idea what it could be ?
Or even am I missing any others I'm not aware of:)
Any help is appreciated :)
Alan, I've just scouted Google Images and came across two Hurricanes of 242 Sq. with the code letters LE * H and LE * M.
Ron
\ said:
Alan, I've just scouted Google Images and came across two Huricanes of 242 Sq. with the code letters LE * H and LE * M.Cheers,
Ron
Thanks very much Ron , I did the same but only got a few , I suppose it's how you word the question :)
All I need now is 6 hurricanes, a bowser, and bourd and just about to sent my mate the dimensions for that :D
Thanks for your help mate
They had Spitfires as well...
A good place to start is Google 242 squadron and go to the more official sites. Having said that there are many sites that are about 242sqdr that have a lot of blanks and ? where there should be serials...
Dont for get the nose art for these. it is quite well known.
This might be helpful
http://www.worldnavalships.com/directory/squadronprofile.php?SquadronID=9
I don't think 242 was equipped with Spitfires during the Battle of Britain.
I stand to be corrected - as usually happens......er' lol
Shhh I just put that to wind im up. LOL
They where indeed a Hurricane unit in that period of time.
To be strictly accurate your bowser should be a Albion AM463 (Matador do a resin one) You could get away with the Brockhouse trailer 350gal bowser (the one in the airfix bomber resupply set) with a Fordson Model N tractor. The David Brown Tractor in the set was much later, and more likely to be seen on bomber stations.
P3054 LE-N; R4115 LE-X; V7203 LE-T; P3485 LE-Y; V6675 LE-V; V7467 LE-D; P2965 LE-X; P3864 LE-U; V6913 LE-G.
If you're wondering about the duplicates, if an airframe was scrapped, returned to a repair unit, or shot down, its replacement would take on the original letter.
Thanks for the extra help folks :)
Edgar the base for this dio is already six foot by two foot so I dont think I'll be able to do the complete squadron but the info is great cheers :)
Ian I did know that 242 was only hurricanes during the BoB was a nice try though:D
QUOTE="Alan 45, post: 237396, member: 22153"]
Edgar the base for this dio is already six foot by two foot so I dont think I'll be able to do the complete squadron but the info is great cheers :) [ /QUOTE]
What scale?
\ said:
QUOTE="Alan 45, post: 237396, member: 22153"]Edgar the base for this dio is already six foot by two foot so I dont think I'll be able to do the complete squadron but the info is great cheers :) [ /QUOTE]
What scale?
1/48 Steve , I'm taking a look at some photos of coltishall to look at how aircraft might have been arranged and any huts and vehicles , I tryed to get a bowser truck but I can't find one
One of two things I'm thinking of , a squadron scramble or down time with pilots and ground crew milling about
It's going to take a fare bit of planing and research which is why I'm starting now , I'm hopping to finish it on BoB day in September :)
If you have deep pockets there are some nice resin bits out there in 1/48 scale....
You could always reduce it to a Flight at "readiness," which was usually (not always) 6 aircraft. At first A Flight used codes A-M, with B Flight using N-Z, but that tended to get thrown out of the window during 1940.
Yeah that's what I'm thinking it will depend on what I choose to do white it :)
So, which child have you sold/or chucked out of their room to house this little lot? :D
Should be spectacular and the time frame means you can take your time and get things just right.
Si:)
\ said:
So, which child have you sold/or chucked out of their room to house this little lot? :D Should be spectacular and the time frame means you can take your time and get things just right.
Si:)
I've just gained another room :)
I suppose spectacular is a word you could use but I don't think anyone will :D
I think the most common will be bloody big lol
O ye of little faith Alan, you can and do make cracking models, you have a good time frame here to set it out and sort out the bits and get the models painted just right. You will be okay.
Si:)
Base will be easy and I'm going with the airfix 1/48 not only because it's pretty easy but inthink it looks better than the Italieri hurricane ,
I'll give it a good go :)
