Could I draw on the combined wisdom of the forum on a couple of problems I have with masking?
1) I need to mask off the front portion of a propeller spinner. I originally thought I could do this by just wrapping an over-wide strip of tape around the end, like a tube, but this leaves very little tape in contact with the plastic, so it doesn't stick very well. Does anyone have a magic trick for this?
2) Liquid mask - I'm using the Vallejo version, but I find that it hardens on the brush very quickly, and once that's happened nothing seems to remove it (water, IPA, cellulose thinners, concentrated sulphuric acid... You get the picture). I'm use an old brush for this, and try to remember to rinse it with water every 30 seconds or so, but even so I'm running out of old brushes! Are there any more user-friendly products out there? Or maybe someone's found something that removes it from brushes once it's dried?
