Hello Joe, for a re-start of the mojo you are doing a great job.
Nuts and bolts, I use Meng nuts and bolts, they come in different sizes with and without washers, you can also get rivets, again in different sizes. Just use a chisel blade to remove them from the plastic board and then pick up with a pointed blade and dip into some c/a and position.
The light guards - had a problem similar with Sherman ones, so used the kit ones to mark out on a thick bit of card and then used that as a guide to bend the brass ones around after running the brass through a lighter flame first to soften it.
As JR said - good to see you back.
