Hi All,
Here's my build of Academy's Jagdpanther, quite decent value at £17! First impressions is that it's a pretty simple kit to make, pretty much a 'shake & bake '.
Further inspection reveals it's a re-box of Tamiya's 70's kit, complete with the mouldings in the hull for adding a motor. The kit comes with working torsion bar suspension.
View attachment 40610View attachment 40613
The drive sprocket housing is attached to the hull by 2 small screws! You can see the gearing inside the housing that's clearly a holdover from the days of motorization.
View attachment 40614View attachment 40615
The rear equipment boxes have some small sinkholes, but some filler will sort them out.
More to follow!
Thanks for looking
Patrick
More to follow!
Thanks for looking
Patrick
