This is my third completion since my recent return to modelling. It's out-of-the-box, except for:
- replacing the guns with the Master brass versions
- adding the P38-type drop tanks from an Academy erm... P38!
- shaving about 1.5 off the main undercarriage legs to make it 'sit' a bit more realistically
All paints are Vallejo with the exception of the red which is Tamiya. I pre-shaded and added a bit of scuffing here and there, and picked out the panel lines with Flory 'Dark Dirt'.
With hindsight, I wish I'd replaced the over-thick undercarriage doors (shouldn't have been too difficult), and in particular, gone for aftermarket transfers. The kit ones were out of register and very thick - all adding up to a bit of a nightmare with gallons of Microsol and a lot of touching up of the checkerboards and the large white numbers. Some silvering is also visible, but that might be down to my inadequate gloss varnishing (I've since purchased some Humbrol Clear to see if that's any easier to work with than the Vallejo).
So... some new things tried out, and several lessons learned. Overall I'm fairly pleased, though.
