There may, or may not be an answer to this question, but I am throwing it out there anyway.
When I got back into the hobby a few years ago, I discovered lots of new stuff, including acrylic paints. The idea of acrylics really appealed to me. "Easy" cleanup, no toxic odors, great range of colors. One brand that stuck out was Vallejo. Model Color, and Model Air seemed like the way to go. Since they produce no toxic fumes I didn't have to worry about having a separate spray area, or a noisy hood to vent the fumes from enamels. Seemed like the perfect solution.
As I worked with these paints, I have discovered a few things. In general, they work fine, and when they do, they work great. The best thing about them to me, is the smooth finish. But, occasionally they can be a hassle. When I first started using them things went ok. Model air right out of the bottle worked fine, at least the first few colors I tried. Lately though, things have been not so great.
I don't know if certain colors are more prone to acting up, or if the consistency from bottle to bottle is lacking. For example, last night I was spraying some RLM76 Model Air on a Bf109. After a few seconds, I started getting clogging, and some weird, small splatters. Finally, after much frustration, I turned my brush to my blotter paper and sprayed a heavy dose for a few seconds. A big, stringy blob came out onto the paper.
Real quick, let me insert here a description of my rig and materials. Airbrush currently is a Badger Patriot 105. My previous airbrush was a Paasche single action, siphon feed. Air source is a Co2 tank with adjustable regulator (thereby eliminating any possibility of moisture in the line).
I am very meticulous in my maintenance. I make sure my brush is clean and never let it sit with anything in it for more than a few seconds.
As for the stuff I use with the paint, I have the following Vallejo products:
Thinner
Cleaner
Flow Enhancer
Retarder Medium
Paint
So, after that long winded background, here is the situation in a nutshell. Why, oh why, if this stuff is recommended to make the paint work, isn't it in the bottle with the paint already? I am not a mad scientist and don't really want to have to mix and experiment with every bottle of Vallejo paint I open. know it is a lot to ask (and probably an impossibility), but I would really like to open a bottle of paint, squirt the desired amount in the cup and do the job. It seems that sometimes paint from bottle to bottle in a set packaged together can be different in consistency from bottle to bottle. In a panzer color set of Model Air one bottle was more like Model Color it was so thick.
Does anybody else have these problems? To hear some people (me included after the first few bottles seemed to work like magic), painting with this stuff is no sweat, and cleanup is a snap. I am really open to suggestions here. Cripes, I think this is the single biggest factor in my slow model building/completion. Building is great, but when it comes to painting, I almost look for opportunities for delays. It just becomes a hassle and frustration.
Thinner
Cleaner
Flow Enhancer
Retarder Medium
Paint
