Acrylic matt varnish?
Dave Ward
What is the most 'matt' matt acrylic varnish? I've been using Vallejo so far, but occasionally it seems to have a sheen to it. I'd be both brush & airbrush applying.
I know new products come on the market all the time, and I wondered if anyone had found a particularly matt product?
I’m quite happy with the Army Painter matt varnish I bought last year. It comes in dropper bottles like Vallejo’s, and is very matt. No idea how it sprays, though, as I’ve not tried that.
I use Hannants Matt. Dilute it with 15% tap water if you need to. Its able to be brush or sprayed on. I find it a very good matt. Way better than Vallejo
I've been pretty happy with Winsor & Newton Galeria . I saw it recommended by a few on here so gave it a go and wasn't disappointed.
Personally I build it up in light coats when spraying and it goes more matt the more you add. I normally do 2 or 3.
Daler Rowney Soluble Matt Acrylic Varnish. Good for brushing.
Personally I find a Tamiya Matt varnish good when sprayed. I haven’t found any particularly good when brushed, so might give the Daler Rowney a try....apparently AK make an ultra Matt varnish, so might be worth trying that one.....
Another vote for Galeria. It looks too thick to spray, but goes on very well. I use a 0,2mm nozzle at about 18 psi.
Exactly this!
The first time I tried it I said to myself "that'll never go through the airbrush!" so I thinned it down with water. It didn't go well.
I then tried it neat and have used it thus since. Through 0.2, 0.4 & 0.5 it just does the job as it is.
I'm using "Mig Lucky varnish - ultra matt 60ml", needs to be aplied in multiple thin layers. I find it very good but it needs to harden 1 or 2 days otherwise the surface feels like velour...
Steven
Dave,
AK interactive AK 183 Ultra Matte Varnish. It will spray or brush on.
Dries totally matt, no or very little odour, check out my Comet in the armoured vehicles completed section, I used it on it.
Mike.
Thanks for all your inputs, I've ordered some AK Ultra Matt ( & some other AK bits ) from John....................
The best I have found Dave is Vallejo matt. They do an acrylic, polurethene & an acrylic/polyurethene.
The best is the acrylic/polyurethene. Takes a fraction more time to cure. It gives a superb finish
plus it is very hard & durable.
Another W&S Galeria user here. :)
I also usually use it neat but recently read it can be thinned 50/50 with IPA. Going to give that a go and see if it makes any difference.
I'm with Mr Day on this - the Daler Rowney artists' Matt varnish is the mattest matt I've found, and is brilliant for getting the look of fabric at scale. I've only ever used it with a brush though.
Dave you won't go wrong with the Ultra, would advise a really good stir and shake. I've tried just about every one, Galeria is good as well .
I strain mine now through a old pop sock stolen from Mrs R:smiling3:
I’d like to try the Daler Rowney, but it appears there are several types...can someone post a picture of the bottle so I buy the right one.....
cheers
tim
Just ordering some AK Ultra too on the back of this thread to see what it's like. I do like my Hannants Matt so it'll be interesting to do a side by side test.
Tried a fair few but this is the best for me.I only use it through an airbrush.
