Ade's F-4F Phantom II WTD 61 "Flight Test"
Nice one Adrian, looking forward to this my tortoises vote must have won it then :)
Although my vote was for the Spit, this looks a nice kit! Looking forward to seeing more
:confused::confused:Yep I like that ans what a decal sheet ( I'll be watching as never built a phantom before. )
Good weathering onthe Mars bar ( looks almost lifelike ) :confused::confused::confused:
Regards
Robert
Just a little update on the office, the decals went on nicely and dried nice and tight to the plastic detail. The seats are now in the front nose section and I have to say its a terrible match up on the two halves, I'll need to so some major seam work if I'm going to have perfect gloss black paint work.
Comments welcomed as always
Adrian
Good luck with this one - looks like a MAJOR build - look forward to seeing progress shots----best o luck ! :)
Hi guys and Gals,
Just wondering if I should add " Remove Before Flight Tags" to my build?
Also is it worth getting the metal under carriage? Looking at the one in the kit it seems details enough.
Thanks in advance
Adrian
The remove before flight tags give realism
The white metal undercarriage ( is it really worth it
Regards
Robert
This is going to be another masterpiece! I will watch this build with wide open eyes!
That cockpit looks real nice, I remember buying a phantom a few years back in the same scale and from Revell and the fit was terrible.
scott
I have a set of PE "Remove Before Flight" tags I will never use if you want them Adrian, I believe they are 1/35 scale but at that sive I guess it won't make a spit of a difference. If you want them PM me your address and I'll put them in an envelope and post them off to you.
