Ade's Lancaster Build
Well I bought the Tamiya kit nearly 2 years ago, spent a fortune on PE and resin bits and then built everything else always meaning to start this kit next. I've seen the builds on here and can say now it wont be anywhere near the quality but I will be using them as reference points, advice always welcomed as always so heres the little bit I've done so far, I did paint the figures a while back but having bought the seatbelts decided against placing them inside.
Adrian
nice start ade looking forward to seeing more of your build.and i know it will be a cracker
i`m in love with the PE stuff,and the job you`re doing its great
mobear
superb work buddy im in the same place as you pe everywhere put in then paint or the other way round
Your additions certainly make the rather bland kit interior a lot more exciting. They look really good.Good luck with the rest of the build,it will be am impressive beast!
Well its been a while but I've got the big girl back out again, the two sections have gone together well but I'm concerned about rubbing it down and loosing the raised detail, so should I take on the massive challenge and re-scribe the whole plane?
View attachment 64137View attachment 64138View attachment 64139
Also got the resin guns to go on, I think they improve the look 10 fold.
Adrian
Adrian doing well there.
But do you need to rub all the panel joints out. Certainly sand the joints but then you only need to scribe those bits of panel lost in rubbing down not the whole model. Am I missing something here ?
The fuselage has all raised lines, if I rub a few down and then scribe em I will have a mix of both, don't think that would look any good?
Adrian
Ah not taken in that they were raised Adrian. Had that problem on one & never more. Tried scribing on either side of the raised area in the hope of producing a raised panel line. Then filled in the crater bit left on each side. Not really very good & a lot of bother when you could be doing more constructive things.
Done a little digging and one chap suggests using Tamiya tape, place it as close as possible leaving a slight gap between two pieces and the use Mr Surfacer to fill the gap, when the tape is removed there should be a slight raised line,,,, or if my luck is anything to go by a huge mess :)
Adrian
Or really thin stretched sprue, to re-instate the panel line. You can then sand it down if it's to big.
Colin M...
