Advice Needed - Revell Alpha
Hi guys!
I am about to get into airbrushing (haven't tried it yet, fed up with brushes not leaving a even layer of paint on larger surfaces) and I need would some advice.
I have received a Revell Alpha compressor from a friend, and I am about to buy an airbrush set (haven't decided what to buy exactly).
I did some reading on the Revell Alpha, and so far I am a bit disappointed because it only creates a maximum pressure of 1bar (from what I can tell that is not sufficient?).
So my question is, should I just buy an airbrush set and give it a go? Or buy a whole set with compressor included?
I am building cars, and I am looking for is an airbrush that will enable me to apply a nice even layer of paint, nothing fancy.
So any tips?
Hi and welcome to the site.
I'd recommend that you (if possible), borrow an airbrush and try blowing some water through with the compressor, if you can maintain a good steady strong stream without fluctuations or pulsing you should be OK.
I suspect however that 1 Bar max pressure may leave you struggling for anything beyond quick spraying sessions.
The cheap chinese compressors build up to about 4 bar and can give out a consistent 1.5-2 bar which is plenty fine for a gravity fed brush and OK with the syphon ones.
If you can't borrow one a cheap chinese gravity fed brush can be had on ebay for about £12 + shipping so you could buy one, try it, if the compressor isn't up to the job get one of the cheap compressors, (£60 ish), I know it sounds pricey but compared to some name brands believe me it's cheap
Hi M1ks and thanks for the advice! Well, the guy who I got the compressor from was airbrushing textiles, and the compressor wasn't powerful enough for the job. So I guess I will be looking at a new compressor too... should I look out for a specific cheap airbrush brand? [what should I avoid? or go for?]
If you want a compressor that will do the job but dont have a lot to spend go along to your nearest 'Machine Mart'.I bought a small compressor from them for £70.It comes with a regulator and guage,but no water trap.The largest model ive sprayed with it was a 1/48 Halifax bomber and it did the jkb with no problems at all.
