Help, it seems I may have inadvertently bought a grown up model to build!
I ordered some paints and such from the shop connected to this forum and one of the kits that found its way to my house was the Airfix 1:48 Hawker Hurricane Mk.1 Tropical.
All was good until I had a look at it and saw that the tropical colour scheme isn't as basic as I first thought. At the front of the wings and underneath the engine there are little red and green "squiggles" (I hear that's the appropriate technical term).
I immediately went into decal shopping mode but I haven't got any yet as I've still not definitely decided that I'm not doing the tropical colour scheme, I'll make that choice when I come to build it.
Next, looking at the kit itself I found that there are lots of little bits that are just begging to snap when I try to remove them from the sprues. Which brings me to my first question.
What do you use to remove the parts (particularly delicate looking parts) from the sprues?
A look at the instructions gave me further cause for alarm. I need to cut a piece off of the lower wing/fuselage section:
What?? This is only supposed to be a skill level 2 kit!
Second question, when you've come across this, what tools have you used to safely and accurately remove parts that need to be removed?
I know I'll be needing a new blade on my modelling knife but apart from that, any suggestions?
Onto the more specific question of Hurricanes.
When I was in my panic looking at interesting decals for Hurricanes I noticed that most of the Mk.1 Hurricanes don't have the large air filter under the engine. This made me do a little bit of research.
I managed to find out (courtesy of Wikipedia) that this was added to Mk.1's as they were going to sandy areas (such as North Africa) and it was later added to later models.
What I couldn't see were any further differences between the Mk.1 with the air filter and other models with the air filter (with the exception of the variants with the external machine guns rather than those with the internal machine guns - like the Mk.1).
Are there any major external differences between the variants?
I'll start a thread when I come to building this one but wanted to get some info first.
