Air brushing problem with Pledge wax (Klear)
mossiepilot
I've given my F-104 an air brushed coat of Pledge multi-surface wax, new formula Klear. and left it to dry, it was left for a week because work and finishing up another kit got in the way. I've just picked it up and noticed pale white lines on the fuselage and in the join between the tail and fuselage, and a general whitening of the colour at the rear of the model,
The front of the plane is OK, not as shiny as I would have liked but OK.
Can anyone help as I don't know what's happened to cause this.
Tony.
Sorry the photos aren't too good think the auto focus focused on the background and not the plane:oops:
Hi Tony,
It might help if you set you camera to "macro", It's usually a flower type symbol on non SLR type cameras. This should allow you to get an in focus when shooting close up shots.
Colin
I would guess Tony that the layer you applied has been to heavy and the excess has drifted downwards into panel lines etc dried and left the white streaks. Klear is not clear . You do not see this when applied in thin coats.
I had similar troubles when trying to airbrush the stuff. Found, when I was (hate the stuff) using the stuff it was best to brush by hand and then in thin coats.
I wonder if giving another thin coat on the problem areas this will thin the white bits down. Others with more experience with the stuff may be able to help here.
Thanks for the reply Laurie, The streaks don't follow panel lines, I tried to do thin coats but it's almost as if the klear has run and left a mark when it dried, also I can't figure out why the back end looks like I've done a mist coat in white. The model was done in one sitting, over about an hour, had to wait for the front to dry before doing the back, and the front has come out OK but the back has this discolouration. Does klear have something in it that needs stirring up and could it have settled while sitting in the paint cup, then got blown onto the model ?
Tony.
I gave up on the stuff. I used to shake it for about 15 minutes before spraying but it still used to pool. Needed a very high pressure just to get it out of the airbrush. There are plenty of people here, I think, who use it successfully. It's very subjective.
Uncle Laurie put me onto Vallejo gloss which is stunning.
Thanks Aiden, I've been looking on line at Vallejo varnishes, Vallejo is my paint of choice and it seems reasonable to use their varnish too. I got the pledge wax stuff because it was cheap and you got loads., hey ho.
I'm off to town on Thurs, I'll look in the LMS and see what they have.
Cheers.
Tony.
I only ever use it on paint work if the panel lines are very fine and I dont want to drown them in varnish. WHEN I use it I always use a soft flat brush. That way you can also keep an eye out with puddles and pooling. wicking them away as they form.
Klear dissolves its self, so make sure its very dry before a second coat.
MY opinion on klear is its good for dipping canopies and other clear parts in, and can be used as a canopy glue. It also protects clear plastic from super glue fogging.
What is this stuff like through an airbrush. Please forgive me if this sound like a daft question.
Tony.
It's great. You need a pressure of at least 20 and it goes on very well. No pooling. Dries very smoothly. Cleaning is a joy too.
But don't forget I'm biased against Klear but others find it works well for them
Tony as the "Young Man" Aidan says Vallejo Varnish is great. All the matt, satin & gloss.
The matt (not sure on the other 2) touches up with out any sign of a join or over lap.
Should avoid the Acrylic Polyurethens Gloss Varnish which Vallejo also make. Just used it & found it strips very easily. Seems to be brittle compared to the Acrylic Resin Gloss.
Despite having mentioned this a number of times make sure Tony you give the brush "immediately" after use a good clean or you will have problems. I steep the nozzle while cleaning the rest in Vallejo Cleaner & give a squirt through of cleaner when finished cleaning.
\ said:
Tony as the "Young Man" Aidan says Vallejo Varnish is great. All the matt, satin & gloss.The matt (not sure on the other 2) touches up with out any sign of a join or over lap.
Should avoid the Acrylic Polyurethens Gloss Varnish which Vallejo also make. Just used it & found it strips very easily. Seems to be brittle compared to the............
The only gloss varnish that I can find in Vallejo's site is 70.510 which I think is their Acrylic Polyurethens Gloss Varnish. So can you please give me details of the Acrylic Resin Gloss (number etc.)
Thanks
Yes Steve here they are.
Acrylic Matt 26.518
Acrylic Satin 26.519
Acrylic Gloss 26.517
From Vallejo's site:
http://www.acrylicosvallejo.com/en_US/model-paints/auxiliary-products/3
Gloss Varnish
Waterbased acrylic varnish with new, quick drying formula, and an acrylic resin of extraordinary hardness and permanence. Protects painted models from dust and scratches, dirt and humidity. Acrylic Varnish should never be applied until the paint has dried completely (see note), and it is recommended to wait at least 24 hours. Varnish should be applied in fine coats at approximately 5-10 minutes intervals.
Presentation:
70.510 Gloss Varnish 17 ml.
26.517 Gloss Varnish 60 ml.
It seems to be the same fluid as the 70.510
I was wrong: 70.510 is not an Acrylic Polyurethane Varnish. I can't find any Acrylic Polyurethane Varnish in Vallejo's site. Do you know the address?
Steve here it is.
http://www.acrylicosvallejo.com/en_US/decorative-arts/auxiliary-products/2
http://www.acrylicosvallejo.com/en_US/media/65a2f7365274da82fe3b0d786827957b.cms/model-faqs-cc001-rev03.pdf
In which it states this.
10.4. What is the difference between the new polyurethane varnish
–refs.62.062 , 063 & 064- and your acrylic varnish?
The most important advantage of this new polyurethane is its superior strength
and resistance to nicks and scratches, which makes it ideal for surfaces
exposed to wear. The varnish is manufactured with a new resin of 100%
polyurethane which is self-leveling and offers a stronger protection than acrylic
varnishes. Basically it has the same properties as our new Polyurethane
Primers, can be applied with a brush or, for airbrushing, and diluted with our
Airbrush Thinner (Ref.71.061). Utensils can be cleaned with water after use.
10.5. Can
i
use your new polyurethane varnish on a model painted
with Model Color?
Yes, the Polyurethane Varnish can be applied on Model Color, Game Color
and Model Air, but make sure that the paint surface is completely dry. The
polyurethane varnishes dry more quickly than the acrylic colors, and form
a hermetic surface. If the base color has not dried completely, humidity
could be trapped under the varnish and cause problems difficult to solve.
\ said:
Steve here it is.http://www.acrylicosvallejo.com/en_US/decorative-arts/auxiliary-products/2
Thanks.
I know 70.510 so will stick to it.
