Hello
I'm new to airbrushing and I've run into a problem. I have an Iwata HP-CS airbrush which is fantastic, but my compessor, is a generic TC-20 with moisture trap. I bought this as a package set off of amazon. I always check the trap for moisture and usually theres a few drops, nothing major. Well, i went a couple of days without checking and there was quite a bit of water in the trap. I'm not sure how this whole thing works but now, everytime i try to airbrush, it looks like water is in the paint because its really thin. I have tried Tamiya and Vallejo Model Air acryic paints and its the same thing. I've taken what i believe is the regualor off of the compressor to see if drying it out works, but it doesnt. I throughly clean my airbrush after each use by taking it apart and I disconnect the hose off the AB and compressor.
I guess my question is, do i need a new compressor? Is there a simple fix for this? Any help would be appreciated.
The link is below to see what it looks like.
Amazon.com: Iwata 4207 HP-CS .35mm Eclipse Airbrush Kit With Airbrush Depot 1 Year Warranty Tankless Compressor and 6 Foot Air Hose Set: Home & Kitchen
Tony
Tony
