Hi guys and gals,
I've recently taken the plunge and bought an airbrush to try painting some of my models with, however I seem to have run into a snag. Whenever I spray with water I get a nice, smooth, continuous output. However when I start using paint, I get a short blast of coloured spray and then it stops. Sometimes if I wiggle the trigger back and forth I might get lucky and get another short blast, but then it stops again. I know it's not the air pressure because it's still kicking air out of the brush - it's just not blowing the paint out. When it does come out, it sprays evenly - there's no spattering or dribbling, or anything like that.
The compressor I'm using is an AS18K with a bottom-feed brush (the kit came with a gravity-fed brush as well, but no matter how much I thinned the paint, that one would not work at all!) and Humbrol acrylic paint thinned with water at a 2:1 ratio. I've even tried filtering the paint to try and get rid or any clumps prior to mixing! If I clean out the brush after this happens, again the water sprays nicely but on using paint it just starts all over again.
Could I have the brush set up wrong? Is it the paint? Is the brush just pants and needs replacing? Any advice or help would be much appreciated.
Cheers!
Paul
Cheers!
Paul
